RPM sensor with directions
Ruba
#1 Post by Ruba » 05 Nov 2021, 01:37
I understand, that for RPM I need a pulse counter and then calculate the rpm, but how would I know the direction?
I found on the internet that if having two sensors with reflectors little shifted we can get the direction. The signal would look like this:
But how do I feed signal from two sensors to Espeasy so that it will give me either positive or negative RPM?
All ideas are appeeciated!
Re: RPM sensor with directions
#2 Post by TD-er » 05 Nov 2021, 01:45
You can have a look at the rotary encoder plugin, which just does that.
Not sure how fast it can keep up, as it is done in software.
Ruba
#3 Post by Ruba » 05 Nov 2021, 12:09
Thanks TD-er for your reply!
I did think about rotary encoders as well as they are by physical construction very similar sensors, but the data output in ESP Easy is not really what I need. Output will be the number of revolutions in either direction, but I would need a number of revolutions per minute.
Without having a rpm function built in to ESP Easy I think about three approaches:
1) With pulse counter that measures time between current and last transmission, then calculate the RPM. To get the direction I would need need to have some logical rules that will read the second (shifted) sensor and then decide either to multiply rpm value by 1 or -1 to get the direction. I think this is not very good option for high RPMs as the measurement of pulse counter is rounded to 1ms.
2) With pulse counter calculate the difference between counts during a period of 1 second and then calculate the RPM. To get the negative or positive direction I need some logic as described in option 1.
3) Use rotary encoder and calculate the value between readings during a period of 1 second, then multiply it with 60 and I have RPM. This works in case rotary encoder values can go negative. Can they?
My RPM readings range from 100 to 3000. So I am concerned that higher RPMs might be inaccurate because of 1ms resolution for pulse counter (I read it somewhere in the forum). And slow RPMs might be a problem if measuring counts for 1 second.
I hope that someone already came across this problem and figured out what would be the best approach to solve it.
Users browsing this forum: No registered users and 28 guests
