Problem flashing Adafruit Feather Huzzah ESP8266
gfield
#1 Post by gfield » 10 Oct 2021, 17:29
Hello!
I got an Adafruit Feather Huzzah ESP8266 module which I can't flash it using the ESP Easy Flasher (0.04.007). The COM-port does not show up (see attached image).
  • I'm using Windows 10.
  • I can find the ESP8266 module under "Manage Devices" as a COM-port (Silicon Labs CP210x USB to UART Bridge)
  • I have successfully flashed the ESP8266 module using Arduino IDE (using a simple LED-blink "sketch").
  • I've tried to run ESP Easy Flasher as administrator
  • I've tried removing the "settings" folder for ESP Easy Flasher
What could be the issue?
Re: Problem flashing Adafruit Feather Huzzah ESP8266
#2 Post by TD-er » 10 Oct 2021, 19:04
Some USB to serial chips are not recognized in this flasher.
You can use Espressif's flasher, which is also included in the zip.
Users browsing this forum: Google [Bot] and 30 guests
