MQTT (JASON) Rule Engine failure ?
kohleIT
#1 Post by kohleIT » 30 Jul 2021, 20:03
Hello experts,
I try to get my measurement to NodeRed transferred via MQTT and JASON.
After some research I could get a hint here in the Forum So I created a rule that formats the “output” as Jason and sent it via MQTT to the Broker.
Basically, it works as long I use a Single Value.
My Target is to Transfer Temperature and Humidity in one JASON.
The Problem is following line:
Publish %sysname%/Sensor_%unit%/Oben,{"Temperture":"[Oben#Temperature]","Humidity":"[Oben#Humidity]"}
The Problem in the "," between the 2 Values. ("[Oben#Temperature]","Humidity")
In MQTT Explorer i can observe that the 2nd part is missing(Humidity). pls have a look on the attached picture.
Rule:
on System#Boot do
  timerSet,1,1
On Rules#Timer=1 do
    Publish %sysname%/Sensor_%unit%/ObenT,{"ObenT":"[Oben#Temperature]"}
    Publish %sysname%/Sensor_%unit%/ObenH,{"ObenH":"[Oben#Humidity]"}
  timerSet,1,1
Log:
EVENT: Rules#Timer=1,1
846382: ACT  : Publish xxx/Sensor_4/Oben,{'Temperture':'26.50','Humidity':'52.60'}
846388: Too many arguments: cmd=Publish Arg1=xxx/Sensor_4/Oben Arg2={'Temperture':'26.50' ExtraArg3='Humidity':'52.60'} lin
846388: Line: _Publish xxx/Sensor_4/Oben,{'Temperture':'26.50','Humidity':'52.60'}_
846388: Command not executed! See: https://github.com/letscontrolit/ESPEasy/issues/2724
846405: Command unknown: Publish xxx/Sensor_4/Oben,{'Temperture':'26.50','Humidity':'52.60'}
846417: ACT  : Publish xxx/Sensor_4/ObenT,{'ObenT':'26.50'}
846441: ACT  : Publish xxx/Sensor_4/ObenH,{'ObenH':'52.60'}
846453: ACT  : timerSet,1,1
Update:
After implementing here the Log, I realized an hint in the Log:
Played a little bit around with different possibilities and I got it fixed by myself.
Put the whole publish command under “ ’ ”
Re: MQTT (JASON) Rule Engine failure ?
#2 Post by TD-er » 30 Jul 2021, 21:14
JSON should use the double quotes. Otherwise it isn't valid JSON.
You could however wrap the publish command argument in other quotes.
For example if you need to use " in your argument, you can wrap the entire argument in single quotes as long as you don't need them.
Also a comma is typically considered an argument separator, so by wrapping the last argument in quotes you get by that problem.
See also this sticky topic for more info: https://github.com/letscontrolit/ESPEasy/issues/2724
Users browsing this forum: Ahrefs [Bot] and 52 guests
