I need some help writing a correct statement in Rules to make sure that a virtual switch in Domoticz follows a GPIO, or PCFGPIO, defined by some rules, e.g. Toggle, using json.
I tried the SendToHTTP command, but I can't find the correct json syntax to send the status of that GPIO to the Domoticz IP.
I want to do this to allow ESP8266 to make some autonomous GPIO decisions, simply then notifying them to Domoticz.
I hope I have explained.
Thank you.
Make Domoticz read a GPIO pin
Re: Make Domoticz read a GPIO pin
Can you use the Domoticz MQTT controller?
Then please have a look at this here: https://espeasy.readthedocs.io/en/lates ... #p029-page
Thanks for the hint.
I was wondering if it were possible using a variable that follows the GPIO state in rules, then I sendtoHTTP the value of this variable to Domoticz.
If yes, which could be the correct syntax?
See the "monitor" command: https://espeasy.readthedocs.io/en/lates ... ernal-gpio
This will send an event as soon as the pin state changes, on which you can act in the rules.
I am using some Sonnofs like relays, which can be triggered by local push button, other ESP or from Domoticz and reports its actual status to Domoticz.
GPIO-0 local push button
GPIO-12 relay
From Domoticz it is switched with:
GPIO-12 relay
On System#Boot do
gpio,12,0
TaskValueSet,3,1,1
on Tlacitko#State do
if [Pom#State]=0
event, change
TaskValueSet,3,1,0
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=163&switchcmd=Off
on change do
if [Relay#State]=0
gpio,12,1
SendToHTTP 192.168.1.253,8080,/json.htm?type=command¶m=switchlight&idx=163&switchcmd=On
gpio,12,0
http://192.168.1.119/control?cmd=gpio,12,1
http://192.168.1.119/control?cmd=gpio,12,0
Users browsing this forum: Ahrefs [Bot] and 43 guests
