Okay, here's the fix. Thanks to Martinus and Drum who've been very helpful!I'm trying to set up a rule to run on a Clock#Time event. Problem seems to be the time passed is Day,Time, and the event triggers once Day is correct - completely dismisses the Time part. For instance, I have:
The goal is to have a relay on PCFGPIO 1 trigger when the time hits 4:30 pm Saturday and start a 2 hour timer. Problem is, the event triggers when it sees Sat.Code: Select all
On Clock#Time=Sat,16:30 do PCFGPIO,1,0 timerSet,1,120 endon
What options do I have here?
Release 95 now supports triggering on Clock#Time events. You can set a trigger based on *either* day,time or all,time.
If you want a trigger on Saturday at 16:30, you'd put:
on Clock#Time=sat,16:30 do
on Clock#Time=all,16:30 do
