Hmmm....both GPIO 1 and 2 needs to be up when booting, and as far as I can read there is no pull down function on ESP-1 ?
how does one connect a normally closed switch to it?
regards
connecting normally closed switch to an ESP-01
Re: connecting normally closed switch to an ESP-01
One RES to the input and the other end of the RES to GND, then one site of the switch to the RES(Input) and the other to 3V3.
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
Here some tips and tricks http://www.forward.com.au/pfod/ESP8266/ ... magic.html
but would that not cause the resistor to become a voltage divider combined with the pull up resistor that I understand is built-in to most GPIO on ESP8266 ?
does unclicking the "Pull up" in tasks disable the pull-up for the GPIO? or can I use "Pin mode x Select an optional boot state for this pin, either output low or high" to force GPIO 1&2 to be up until it has finished booting?
Users browsing this forum: Bing [Bot] and 0 guests
