Heating - DL-Bus (Technische Alternative) not found
maxslo
#1 Post by maxslo » 30 May 2021, 19:14
I have installed ESPEasy_test_C_ESP8266_4M1M on D1 Mini, but under Tasks i cannot find the device "Heating - DL-Bus (Technische Alternative)".
It should be the right version. (Test C)
What I am doing wrong?
BR
Max
Re: Heating - DL-Bus (Technische Alternative) not found
#2 Post by TD-er » 30 May 2021, 20:28
It is indeed mentioned in the "Testing C" build, but the "Limit build size" disables it.
So it is (sadly) correct that it is not present in that build.
I will make it available in the next build.
I will try if it will fit in either the "testing C" or "energy" build.
#3 Post by TD-er » 30 May 2021, 20:34
Made a build where it should be included: https://www.dropbox.com/s/63cdwhnty6olr ... M.bin?dl=0
#4 Post by Ath » 30 May 2021, 20:55
TD-er wrote: 30 May 2021, 20:34 Made a build where it should be included: ...
I was also looking at this, but you already got this, so I won't PR anything. Unless you want me to ;)
#5 Post by TD-er » 30 May 2021, 22:39
Well you made the split, so I guess you're the perfect man for the job :)
maxslo
#6 Post by maxslo » 31 May 2021, 10:56
Thanks a lot. I flashed it now and the device is available
I hope it works with the UVR1611. I'll tell you later
BR
Max
espeasyUser
#7 Post by espeasyUser » 09 Feb 2024, 08:49
Hi all,
does the ESPEasy DL-Bus plugin also support the master device functionality for the Cora DL-bus, i.e. is it possible to directly connect a DL-bus sensor device like the TA Fristar 3 WP to ESPEasy. With "direct connect" I mean without using a TA UVRxy and/or TA CMI.
I want to connect my TA Fristar 3 WP to my smart home system using espeasy in order to read/wrote cora-dl bus variables.
Users browsing this forum: Bing [Bot] and 3 guests
