Espeasy et jeedom
Espeasy et jeedom
Bonjour,
a tous merci au createurs de espeasy pour cet excellent travail.
pensez vous qu une intergration de l envoi de valeur de sonde ds18b20 vers un system jeedom https://www.jeedom.com/ soit possible de maniere native ...
serait il possible d integrer cela dans une future version
merci
merci
Re: Espeasy et jeedom
here te code i use in my esp with lua
- Creation d'une fonction qui va préparer la requete a envoyer à Jeedom pour mettre notre capteur virtuel à jour.
function build_post_request(path, key, value)
print("Contruction requete HTTP pour Jeedom")
payload = key .. "=" .. tostring(value)
return "POST " .. path .. " HTTP/1.1\r\n" ..
"Host: " .. server_ip .. "\r\n" ..
"Connection: close\r\n" ..
"Content-Type: application/x-www-form-urlencoded\r\n" ..
"Content-Length: " .. string.len(payload) .. "\r\n" ..
"\r\n" .. payload
end
-- Création de la fonction qui envoit la requête à Jeedom
function send_temperature(value)
print("Envoie temperature vers Jeedom")
temp=gettemp(gpio0)
block = true
sk = net.createConnection(net.TCP, 0)
sk:on("connection", function(sck)
request = build_post_request("/jeedom/core/api/jeeApi.php?apikey="..api_key.."&type=virtual&id="..id_capteur.."&", "value", value)
sk:send(request, function()
sk:close()
block = false
end)
end)
sk:connect(server_port, server_ip)
end
"\r\n" .. payload
end
temp=gettemp(gpio0)
block = true
sk:close()
block = false
end)
end)
end
Vince, you have to speak english here.
I think Lunarock already explain how to on jeedom forum, using MQTT (Openhab MQTT protocole). You have to installé MQTT plug in.
I sorry for my french speeking in the first post.
my goal is to do the same like thinkspeak but with jeedom and without MQTT plugin is it possible to create the http request .. for jeedom ?
ESP Easy is open source, if you want it : try to do it by your own !
Pas de probleme pour le français tu ne savais pas.
hi deennoo, i had sent you a PM.
@deeno ... i will try it ... it seems that espeasy is based on .ino script is it correct ???
can i change one of them to create the "jeedom" confi in the web interface ?
can i have to create a new _C00x.ino file for jeedom based on thinspeak model ???
on beta r91 that done, you have generic http protocole
i find only r78 ... where to find r91??
maybe on github ? 2 raw under r78 ?
I see, but i will say a firmware in r91 version ...
i find,
compiled and upload r92 in a esp-01 but now ... red and blue are light...
i hope this is only a problen of option with generic esp8266 ... in arduino ide...
i choosse 512k ....
compile without any error...
i choosse 512k ....
@Deennoo
complie and load r92, but i m unable to uses generic hhtp to send value to jeedom....
in generic there is no field to enter api-key needed by jeedom
I dont use jeedom sorry.
You have to find your way...
@deenno,
i will try to modify the _c00x.ino thinspeak for jeedom ...
and give this to the community ,,, and sone perhaps could add this in a future release.... R150![Lach :-)](./images/smilies/icon_e_smile.gif)
