I have a self built ESP8266 with a PN532 connected to it that has worked for months. After some hardware modifications, I have updated ESPEasy from build 20191127 to the last one. After that, when I turned on and off several times a low power light (5W), the PN532 stops working until it is reset through RSTPDN pin.
In the build 20191127, ESPEasy can detect this situation as "BUS Error" and reset PN532 automatically as you can see in the following log:
But with newer versions, the software doesn't detect this error and the PN532 can't read a tag anymore. I have tested several newer versions with the same results.
Does anyone have had a similar issue? Is this a bug?
I2C bus error - PN532
- Screenshot from 2021-04-15 18-08-59.png (171.19 KiB) Viewed 7906 times
Re: I2C bus error - PN532
This old Github ticket explains the PN532 Bus Error bug: https://github.com/esp8266/Arduino/issues/1541
As noted in the ticket, the issue may be solved via the clock stretching value. In case it helps you, try changing Tools->Advanced->I2C ClockStretchLimit to 2000.
BTW, I don't use the PN532. So I cannot test this.
Thank you Thomas,
I will do some tests to see if adjusting Stretch Limit could resolve this issue.
BTW, I think that if older versions can detect bus errors, the newer ones could do the same. May be the right thing to do is open an issue or PR in GitHub....
Antonio,
Antonio,
