Trigger Mointor GPIO event (was resolved quickly)
Dondolo
#1 Post by Dondolo » 21 Mar 2021, 14:18
I switch a GPIO with http: //192....=gpio,15,1.
I want to monitor the GPIO using the Monitor, GPIO, 15 command.
How can I trigger an event when the value changes?
I tried the following rule:
on System#Boot do
Monitor,GPIO,15
on plugin#gpio#pinstate#15 do
Publish,%sysname%/GPIO/Lüfter,[plugin#gpio#pinstate#15]
TaskValueSet 12,1,[plugin#gpio#pinstate#15]
on [plugin#gpio#pinstate#15]=1 do
on [plugin#gpio#pinstate#15]=0 do
GravityRZ
Re: Trigger Mointor GPIO event
#2 Post by GravityRZ » 21 Mar 2021, 15:52
really easy
On GPIO#15=0 do
do your stuff
On GPIO#15=1 do
do your stuff
#3 Post by TD-er » 21 Mar 2021, 16:39
Also using %eventvalue1% in your rules may make things a lot simpler:
on GPIO#15 do
  Publish,%sysname%/GPIO/Lüfter,%eventvalue1%
  TaskValueSet 12,1,%eventvalue1%
One thing I am not sure about is whether the umlaut in the topic is working.
I don't know what character(s) is sent here and also if the MQTT broker may translate extended ASCII into the same Unicode character to match the topic.
ESPEasy itself does nothing special regarding Unicode characters. It just considers them as (signed) 8 bit characters and thus does not perform any conversion.
Another thing to keep in mind.
Never use [] in the on...do part of the rules.
A [] syntax is used to replace what's inside.
Dondolo
Re: Trigger Mointor GPIO event (was resolved quickly)
#4 Post by Dondolo » 21 Mar 2021, 17:12
Thank you for the quick solution!
Dondolo
#5 Post by Dondolo » 28 Mar 2021, 13:19
I still have a question when the ESP reboots, how can I query the GPIO status and send it to the broker with publish?
Dondolo
#7 Post by Dondolo » 28 Mar 2021, 14:46
I'm sorry, have to ask again.
What does the rule have to look like so that the GPIo status is published?
This is not how it works:
on System#Boot do
Monitor,GPIO,14
timerSet,1,10
let,1,[Plugin#GPIO#Pinstate#14]
on MQTT#Connected do
Publish,Test/GPIO14,[var#1]
TaskValueSet 12,1,[var#1]
on GPIO#14 do
  Publish,Test/GPIO,%eventvalue1%
#8 Post by TD-er » 28 Mar 2021, 14:53
Are you interested in the state at boot, or when you publish it on MQTT#connected ?
Also you're publishing to 2 different topics. Is that intentional?
Dondolo
#9 Post by Dondolo » 28 Mar 2021, 16:20
The background is, I use Iobroker with the Jarves View. There I switch a relay on the ESP (espeasy) with blockly script.
When switching, the command goes e.g.
http: //192.168.xxx.xx/control? cmd = gpio, 15.1
Out. -Light is on-
When the ESP boots, the GPIO status (lamp on / off) should be published via mqtt. -Query when booting-
When switching, the GPIO status (on / off - 0/1) changes as planned - query in operation-
Hence different topics
I am not sure whether the GPIO status is transmitted at all when booting. There is still no connection to the broker via mqtt.
#10 Post by TD-er » 28 Mar 2021, 18:25
I do understand why you want to publish it at mqtt#connected.
But I don't know how long it takes till you have a connection, so maybe it is not the best idea to publish the state as it was at boot, but rather the actual state.
  Publish,Test/GPIO14,[Plugin#GPIO#Pinstate#14]
Users browsing this forum: Ahrefs [Bot] and 32 guests
