after 2 years of development, i have finished my ESPeasy Hardware project and yes i don't worked permanently on this project.
![Erg Blij :D](./images/smilies/icon_e_biggrin.gif)
The goal was a PCB with terminals to connect the DS18B20 sensors and everything should fit in a cheap Enclosure for Aliexpress, unfortunately this project ended a little bigger.
![Kwaadaardig :twisted:](./images/smilies/icon_twisted.gif)
During the CAD drawing, I kept adding sensors/options, you want to use all GPIOs, but at one point i had to stop adding Functions, otherwise this thing will get too complicated. Just an example, you can use "relay 1" or the "RS485 interface" or the GPIO15, but not all together.
1x Analog Input 0-36V DC, MCP3221A5T-I/OT
1x Digital Input 5V or 24V, galvanically isolate with Optocoupler 6N137S1(TA)
3x Relay with 6A 400 VAC 125 VDC switching current
1x DS18B20 Onboard and to the Terminal
5x WS2812B Neopixel LED Onboard or external with Terminal
1x Touchbutton for Oled Control TTP223
1x OLED 128x28 over I2C
1x I2C Output to Terminal
1x Onboard BMP280 or similar
1x RS485 with MAX485CSA+T (Not Tested)
and everything fits in a cheap 95x90x40mm aliexpress housing.
![Lach :)](./images/smilies/icon_e_smile.gif)
This PCB is also compatible with the Aircookie / WLED project.
I do not want to sell this board on tindie or somewhere and I am not interested to making money, I just want to push the ESPEasy project.
When I have tested everything I will publish the circuit diagram and the PCB on EASYEDA.com and everyone can order a board from JLCPCB.
The Price for 10 Boards with SMT Assembly is $68.96 +Shipping.
If someone is interested on PCB he should get in touch. I am happy to send you a board to test, but only in Europe.
I'm already working on the next variant, 99% with SMT components and a little smaller.
if someone is interested we could make a thread for the design of an ESPeasy hardware?
