MLX90614 with ESp8266 and EspEasy 1037.55
Hi there,
the MLX90614 IC2 infrared sensor only shows 1037.55.
unfortunately I only get the value 1037.55 regardless of whether the object or ambient temperature is
displayed under ESP_Easy_mega_20201022_normal_ESP8266_4M1M.
Initially, and only as a flash, a realistic temperature value was displayed.
Have already tried the following without success:
- current and older version of EspEasy installed
-3V or 5V
-IC2 clocking set to 100000Hz, connected alone or with another sensor
-ESP8266 changed
-IC2 used with pullup, IC2 address is 05xA
Anyone have an idea what else I could do?
Hi there,
-3V or 5V
-ESP8266 changed
Re: MLX90614 with ESp8266 and EspEasy 1037.55
Hmm that plugin is not changed for a while and also not a lot of issues about it.
So either the issue you're seeing is perhaps more hardware related, or it isn't used a lot.
What value of pull-up resistors do you use?
How long is the cable?
Does the sensor show up at that address when you perform an I2C scan?
Hi TD-er,
Thanks for the feedback.
Do you mean that the sensor is defective?
First I tried the internal resistors,
then with 10kOhm, 3.3kOhm and with 50kOhm everything was unsuccessful.
With an LCD and an ADS115 on the IC2 bus, I occasionally get values.
The cable is approx. 20 cm long.
The address for the IC2 scan is displayed with 0x5A.
26538: EVENT: infrarot#Temperature=1037.55
26577: ACT : lcd,1,1,1037.55
26638: EVENT: DummyCo2#Co2=0.00
26738: EVENT: DummyCo2#=0.00
27491: MLX90614 : Temperature: 23.45
I'm not sure if it is defective.
More likely the connection is flaky.
Which pins do you use for the I2C? Just the standard ones? (4 & 5)
20 cm long wire should not be a problem.
And if you're using some kind of pull-up resistors (when they are not already present on the sensor boards) between 3k and 10k it should be OK.
That sounds like those are also flaky?With an LCD and an ADS115 on the IC2 bus, I occasionally get values.
yes i use standard pin D4 / D5 for IC2.
The sensor is installed on a breakboard with 2 x10kOhm resistors,
Actually, it doesn't need any additional resistance.
The LCD works fine, the IC2 connection works.
I assume that it is defective or processed improperly.
Let's see if I can exchange the sensor.
Thanks for your support.
Greetings Dondolo
Greetings Dondolo
Please check your wires, I've seen so many of those cheap breakout-board wires having no, or bad, connections inside, I test 'm all individually using a multimeter (and wiggling the wire a bit) before ever using them, to avoid any dissappointment.
Maybe also check with a build of roughly a year ago.
A while ago (not sure about the timeline...) the code for I2C was changed in the esp8266/Arduino core.
This lead to a number of sensors showing issues. Most of those issues were resolved by lowering the I2C clock for them, but that's something you already tried.
Still I would love to know if it does work with a version of let's say Q1 of 2020.
Hi Ath,
checked all cables and used them without a breakboard. Nothing helped but the note from TD-er below helped, thanks for the support.
Thanks for the hint, it worked stably with the following version.TD-er wrote: ↑23 Jan 2021, 11:07 Maybe also check with a build of roughly a year ago.
ESP_Easy_mega-20200204_normal_ESP8266_4M1M.bin
Can I then no longer update the current version?
Not sure if you kept an eye on the commits for this repo?
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
Whenever we find such a problem we try to fix it.
So for now, until it is fixed, you should use an older version for this specific setup.
Thanks for the hint with the old version, had the same issue with the MLX90614 sensor.
Anything that I can do to help you guys with debugging?
I have ordered one, so as soon as that one arrives, I will have a look at the plugin and when I have a test build, I will try to remember to post it here also (made an issue for it on GitHub)
