I'm honestly not sure if this is a problem or expected behavoir, but as it's something I noticed, I figured I'd ask.
I have an RFLink kit from Nodo shop built, along with the wifi adapter and a NodeMCU. When I remove the wifi board and connect a terminal program via USB to the mega, everything works fine. I get messages when I trigger a sensor, and I can issue commands such as 10;PING; or 10;VERSION;
Things change when I connect the wifi board. I have the NodeMCU flashed with the esp-link firmware (https://github.com/jeelabs/esp-link) and it appears to work for receive - with it running, connecting to the esp-link web interface I can see the data from the RFLink. However, with the board connect, it seems that I cannot *send* commands like 10;PING; to the RFLink, either through the web console or through the still-attached USB cable. Both see the data RFLink sends, but neither seems able to send commands.
Anyone have any ideas on what's going on here? Is this an indication of a problem or expected behavior?
Serial issues?
Re: Serial issues?
I had the same issue and found out that only ONE serial port can be active at any time if you want to send signals. You can have both active if you want to monitor only, but if you want to control stuff, you have to choose between using the USB Serial or the Ser2Net connection on the WiFi.
(As far as I can tell, and based on the fact that pins 0 and 1 of the MEGA connect serial port 0 through to the USB device port, the USB Serial port and Tx0/Rx0 seem to be galvanically connected, and thus the signals sent on one, are drawn to ground by the other and v.v., so it'd only work if both sent the exact same sequence at the exact same time!)
Re: Serial issues?
I am experiencing the same issue with my ESP01 to RFLINK connection. RX is OK. TX commands (i.e 10;PING;) can be seen in ESP01 log but do not seem to get transmitted to the Arduino / RFLINK board.
The RFLINK board will TX happily when connected via USB however.
Has anyone come across a solution to this?
Re: Serial issues?
Does the ESP add CR/LF (carriage return/line feed) to the commands that go to RFlink?
Re: Serial issues?
It doesn't appear to. I may have to capture the raw output from the ESP.
I may also try putting the TX in via the USB port by cutting up a USB cable.
- Capture.PNG (33.94 KiB) Viewed 12348 times
Re: Serial issues?
Just thought I'd provide an update on this. I now have it receiving and transmitting really reliably using MQTT instead of ser2net. I migrated away from ESPEasy to an alternative o/s but it should still work if set up correctly.
