Hi guys, I "designed" this based on the the size of 3 18650 holders (maybe overkill I know, in //). The point is to use the 4 analog input of the ADS1115 with capacity moisture sensors like this :
The A0 of the Esp will be to monitor the batteries. I may use I²C with an Oled & motion sensor to display values. May also add solar panel...
Here's where I am so far, any advice is welcome.
Wich gives this (not optimized with copper for clarity).
Voilà, ideas, comments, warnings welcome.
ADS1115 Board for soil moisture monitoring (or any analog, really) some thoughts guys ?
- Plant Monitor V3 SMD.7z
- (31.17 KiB) Downloaded 259 times
Re: ADS1115 Board for soil moisture monitoring (or any analog, really) some thoughts guys ?
Maybe also add a header for an extra 3v3 input?
There are Wemos modules out there with limited 3v3 voltage regulators.
For example one of those: https://nl.aliexpress.com/item/32829322098.html
Indeed. Thanks I'll do that and redesign it.
Users browsing this forum: Ahrefs [Bot] and 0 guests
