Just after pairing all my Somfy RTS blinds with my RFLink I lost the communication between my real remote and my blinds.
The pairing button doesn't work for all my remote did someone already has this issue ? Is there a solution in order to repairing the real remote ?
RFLink - RTS remote control removed
Re: RFLink - RTS remote control removed
RFLink should not use the same ID as your original remote.
Also make sure not too add too many remote ID's to your blinds
Yes it was my first mistake but now I fix this issue.
I want to re pair my remote to my blinds how can I do that ? I've seen somfy tuto but all my blinds are wired to the same power link and so I can't just disconnect a single blind how
Did a command exist on the rflink to send a sync mode to my blind ?
Not sure if you found a solution (Your post was from Sep 2020) but,
I have Somfy Sonese 30 Blinds (which are Wireless/LiIon not wired) and they have a programming button on them (near where I plug in the charger to charge the battery).
If I press that for 3-4 seconds the blinds go into programming mode and then just need to press the programming button on the remote to pair them.
Does yours have a programming button like that?
G./
G./
