It seems that the formula functuion in MQTT import does not work.
I run:
Build:⋄ 20107 - Mega
System Libraries:⋄ ESP82xx Core 5473656e, NONOS SDK 2.2.2-dev(a58da79), LWIP: 2.1.2 PUYA support
Git Build:⋄ mega-20200608
Plugin Count:⋄ 83 [Normal] [Testing]
on a Wemos.
I expect : %value%/1000 to give a new value divided by a 1000, but that does not happen
Formula in MQTT import does not seem to work
- mqtt formula 2.PNG (34.15 KiB) Viewed 15244 times
Re: Formula in MQTT import does not seem to work
Sounds like a bug.
Yep and I think a similar one has also been reported for another plugin.
Pulse counter maybe?
I guess it may be related to when the call to sendData is made...
Okay, good to hear it is under control
