Protocol AB400D : Isi it possible to emit from RFlink ?
sorg
#1 Post by sorg » 29 Apr 2017, 09:12
Hi!
I have an old RF433 Otio remote control.
After using it, i can see that Rflink sees it as a "AB400D" device.
When pressing the first button, i receive the following:
20;6E;AB400D;ID=60;SWITCH=28;CMD=OFF;
The other buttons of the remote are switch number: 5, 13, 22 26 ...
The switch numbering is quite odd...
I am now trying to replay the command with the rflink, and here is what i get:
10;AB400D;000060;28;ON;
20;BF;CMD UNKNOWN;
Why is it an unknown command ? Is there something wrong in my syntax of the command ?
Or is it impossible to emit AB400D from RFlink ?
Stuntteam
Site Beheer
Re: Protocol AB400D : Isi it possible to emit from RFlink ?
#2 Post by Stuntteam » 29 Apr 2017, 09:26
First try the rffind option: http://www.nemcon.nl/blog2/faq#RFFind
If that is also not working, get some debug data as explained here (http://www.nemcon.nl/blog2/development) and mail that to frankzirrone@gmail.com
frootloops
#3 Post by frootloops » 22 May 2020, 22:00
Hi, was there ever a solution/answer to this? Did you get it working?
I have exactly the same issue now
receive
20;02;AB400D;ID=50;SWITCH=7;CMD=ON;
replay
10;AB400D;000050;7;ON;
also tried
10;AB400D;50;7;ON;
results in
20;D8;CMD UNKNOWN;
My setup is rpi/rflink/node-red
any help appreciated.
cheers
Users browsing this forum: padrino and 2 guests
