i am not sure about the Syntax (again
![Bedroeft :(](./images/smilies/icon_e_sad.gif)
i do not have the device at home, so i have to make sure the code is working when i upload it to the device which controls some big gas heaters.
What i try to do is an emergency plan when my houscontrolling software crashes.
So in the case MQTT is disconnected i want the heaters to switch on and off between 15-16 degree untill MQTT Broker is online again.
Is this the right code ? Or would you guys change it ?
on MQTT#Connected do
timerSet,8,0
on MQTT#Disconnected do
timerSet,8,60
On Rules#Timer=8 do
if [Unten#Temp]<15
mcpgpio,1,1
if [Unten#Temp]>16
mcpgpio,1,0
timerSet,8,60
