Esp Easy 32
mega-20191208
451780: WD : Uptime 8 ConnectFailures
Not connect NTP server
ESPEASY32 not connect NTP server
Re: ESPEASY32 not connect NTP server
What NTP service do you use?
Just checked NTP and leave the rest empty?
- budman1758
Works fine like that with ESP8266.
Does the node show a DNS and gateway in the sysinfo page?
You could try leaving the NTP host field empty. It will then query a random server in the ntp pool. (which will also fail if no DNS and/or gateway is set)
Use "global" NTP
