Looking at the logs, it's not the sensor but some humidity correction based on temperature.
Now I have set a temperature correction (as is normal) but this *should not* alter the pressure and humidity as that is based on internal die measurements, not the temperature measurement reported (see BOSCH forum).
At least as far as I know and Bosch are saying, I think.
I can see no way to disable this feature.
For a start is should never adjust it to >100% !
At the very least it should be user selectable to adjust humidity.
BME280: Apply temp offset -6.60C humidity 38.21% => 46.91% temperature 25.28C => 18.68C dew point 7.05C
Unfortunately I don't have it showing 110% at the moment.
Build version 2019-12-22 17:09:29
BME280 on NodeMCU V2
(and SDS011 sending via one long JSON string over mqtt)
