Supported device Waveman not enabled?
Pugo
#1 Post by Pugo » 29 Dec 2016, 01:13
Thanks for all your work with RFLink!
I tried using some Waveman switches today. According to the list of supported devices it should work, but it does not seem to have a plugin in the current versions and I can't see any code in the publicly available source code.
Can anyone please tell if it is supposed to work?
When I manually register a Waveman switch in Domoticz, with house code and device number it sends commands like these:
10;Waveman;000050;1;ON
10;Waveman;000050;1;OFF
but the log says:
2016-12-29 00:52:54.775 Error: RFLink: Error/Unknown command received!...
When I check what RFLink outputs when I press my Waveman remote it's things like:
20;88;Kaku;ID=50;SWITCH=4;CMD=ON;
20;89;TriState;ID=0aa000;SWITCH=0;CMD=OFF;
and sometimes (for same remote control keys) garbage like:
20;8D;DEBUG;Pulses=50;Pulses(uSec)=152e200b07231f0b07231f0b07231f0b072307230723072307230723072307230823072307231f0b07231f0b07231f0b07e9;
20;8E;DEBUG;Pulses=36;Pulses(uSec)=200a072106220721072107210621072307230723072307231f0b07231f0b07231f0b07e9;
20;8F;DEBUG;Pulses=44;Pulses(uSec)=200a07211d0a06211d0a062106210723072307230723072307230723072307231f0b07231f0a07231f0b07e9;
20;90;DEBUG;Pulses=40;Pulses(uSec)=200a06211d0a062107210621072107230723072307230723072307231f0b07231f0b06231f0b07e9;
I guess that the fact that Domoticz tries to output a Waveman command to RFLink and that it's listed in the supported devices list indicates that it at some point has worked?
I really wish that I could see the latest source code. As an experienced developer that would give me all the answers and I would be able to fix a new module if it shows out to be missing. Is there any plans on putting the source on for example GitHub?
:P
Stuntteam
Site Beheer
Re: Supported device Waveman not enabled?
#2 Post by Stuntteam » 06 Jan 2017, 00:31
Waveman has been tested and should be working but not every remote out there is the same.
Your remote might be incorrectly detected.
Please make a debug log as explained on this page: http://www.nemcon.nl/blog2/development
and contact me via frankzirrone@gmail.com
Then we will work out a solution.
thomasol
#3 Post by thomasol » 20 Aug 2019, 17:25
Is there a solution to this? I suffer from the same problem.
I posted this at the Domoticz forum : https://www.domoticz.com/forum/viewtopi ... c0#p222008
I am not able to determine whether its a problem in RFLink or Domoticz or a user errror, so I do need assistance. :|
