Im making a thermostat for my brother he have a broiler chicken farm. he want to turn on and off the cooling system based on the temperature.
Q-1) is their any option to turn on the cooling system based on the Heat Index calculated using Temperature & Relative Humidity using EspEasy ?. i did it before using "DHT.h" in arduino. See the images below. temperature range is between 20 to 30 °C but humidity is affecting too much, range between 35 to 60 %.
Q-2) how can i store the trigger value using web call http://<easyespio>/control?cmd=TaskValueSet,4,1,29 ? and use after the power failure.
im making a mobile app (see image below) using https://thunkable.com to control the thermostat. so my brother can easily set the trigger value. i don't want to give espeasy web ui access to him.
thunkable experience : as a ui/ux designer i like very much. its very easy to make nice looking app. using web call and json capability we can make good looking dashboards.
Any way to calculate Heat Index usign DHTxx plugin ? + Store the set value and use after power on
Users browsing this forum: Bing [Bot] and 34 guests
