MQTT Publishing by boot
pw444
#1 Post by pw444 » 10 May 2019, 14:55
Hia,
I'm trying to publish the state of the device, as
On System#Boot do
 let,1,0
 // gpio 2 -> relay state high = relay off
 GPIO,2,1
 Publish,%sysname%/status,Light Off
on pb01#value do
   gpiotoggle,2
   if [VAR#1]=0
    let,1,1 // state on
    Publish,%sysname%/status,Light On
    let,1,0 // state off
on pb01on do
  GPIO,2,0
  let,1,1
on pb01off do
  GPIO,2,1
  let,1,0
on pb01sw do
  gpiotoggle,2
  if [VAR#1]=0
    let,1,1 // state on
but by mqtt-explorer, the publish of on system#boot is not presented, showing:
192.168.1.6 > > Lamp-0101> status LWT = Connected
By Controller, i have:
openhab mqtt
ip: 192.168.1.6
Controller Subscribe: /%sysname%/#
Controller Publish: /%sysname%/%tskname%/%valname%
enabled: yes
But none of those is published either.
Any hint?
THX in advance
Re: MQTT Publishing by boot
#2 Post by grovkillen » 10 May 2019, 15:22
At boot the connection to your network is not ready. Use the event MQTT#Connected instead.
https://espeasy.readthedocs.io/en/lates ... vents.html
pw444
#3 Post by pw444 » 10 May 2019, 15:45
Thank you.
By MQTT#Connected will it perforn once after boot or every time when connecting, i.e, a netorwork disconnection, but no reboot and change of state?
And regarding controllers:
openhab mqtt
ip: 192.168.1.6
enabled: yes
Thx!
#4 Post by grovkillen » 10 May 2019, 16:45
Yeah that is correct. But then you should add a timer at boot and when that one trigger publish.
pw444
#5 Post by pw444 » 10 May 2019, 23:45
Thx!
i did the following:
// pb01   - gpio 0 - D5
// output - gpio 2 - D3
// boots off
On System#Boot do
 let,1,0
 GPIO,2,1
on MQTT#Connected do
 event,publishstatus
on pb01#onoff do
   gpiotoggle,2
   if [VAR#1]=0
    let,1,1 // state on
    event,publishstatus
    event,publishstatus
on pb01on do
  GPIO,2,0
  let,1,1
  event,publishstatus
on pb01off do
  GPIO,2,1
  let,1,0
  event,publishstatus
on pb01sw do
  gpiotoggle,2
  if [VAR#1]=0
    let,1,1 // state on
    event,publishstatus
    event,publishstatus
On publishstatus do
   Publish,%sysname%/pb01/onoff,%v1%
so, by network reconnection, i have the actual state and by reboot, the default state, it's working fine.
by mqtt-explorer, all ok, except that the var is showed as:
onoff = 0.00
Is there a way to cut the decimals, so i have onoff = 0, instead of onoff = 0.00?
TIA
#6 Post by grovkillen » 11 May 2019, 10:10
You can try the [VAR#1] syntax since the %v1% will convert the float value to a string. If that still add the decimals you could do it like this:
On publishstatus do
  If [VAR#1]=1
    Publish,%sysname%/pb01/onoff,1
  Else
    Publish,%sysname%/pb01/onoff,0
  Endif
pw444
#7 Post by pw444 » 11 May 2019, 18:31
Ok, [VAR#1] also ouputs 1.00 or 0.00, so accepted your suggesttion ;-) Thx a lot.
BTW, by Controller, i have:
openhab mqtt
ip: 192.168.1.6
enabled: yes
Why does my mqtt server does not sows the %sysname% by subscription?
and what is the controller publish is for?
TIA
#8 Post by grovkillen » 11 May 2019, 19:18
That's the syntax used by the task devices when the "send to controller is checked". And please remember that the first / is also part of the topic. But it's considered bad practice to use a leading front slash.
pw444
#9 Post by pw444 » 14 May 2019, 16:47
thx!
just one stupid question.
using my browser, i can control it with i.e. http://192.168.1.5/control?cmd=event,pb01sw
how could you do the same using the mqtt broker (mosquito)?
TIA
#10 Post by grovkillen » 14 May 2019, 17:06
You post to the topic of your device and add the extra level "CMD" and send the command as the payload. Please read the docs: https://espeasy.readthedocs.io/en/lates ... mmand.html
pw444
#11 Post by pw444 » 14 May 2019, 19:12
Yes, i did read it, but could not find how, that's why i asked for an example based on the rules, so i can figure out.
MQTT <MQTT subscribe template>/cmd with payload: <command>
i was able so far to figure out:
mosquitto_pub -h 192.168.1.6 -t "/Lamp-0101/gpio/2" -m "1"
what i'm asking is how to use the:
on pb01#onoff
on pb01on do
on pb01off do
on pb01sw do
i'm not finding out how...
#12 Post by grovkillen » 14 May 2019, 19:35
The command would then be
Event,pb01#onoff
mosquitto_pub -h 192.168.1.6 -t "/Lamp-0101/cmd" -m "Event,pb01#onoff"
pw444
#13 Post by pw444 » 14 May 2019, 19:40
thx!!!
waspie
#14 Post by waspie » 15 May 2019, 21:20
grovkillen wrote: 14 May 2019, 19:35 The command would then be
Event,pb01#onoff
i don't have to do this by mqtt import plugin?
#15 Post by grovkillen » 15 May 2019, 21:31
No, the MQTT import it's only used to import float values (numbers). You can of course use values to trigger rules but that is not necessary in this case.
Users browsing this forum: Bing [Bot] and 1 guest
