Rflinkloader fault
About receivers, transmitters, transceivers, connections, antennas etc.
derksuh
Rflinkloader fault
#1 Post by derksuh » 25 Feb 2019, 20:27
Hello all,
I’m trying to install the latest version of rflink on my arduino mega, but it won’t program it. When i download a sketch with arduino ide it works fine. With rf link loader i see the following debug.
Serial port test:
Serial port ok
Serial port test done
param: -p atmega2560 -c stk500v2 -P \\.\COM3 -b 115200 -U flash:w: C... location of file on computer.
Execute external program:
Exitcode 1
External program ended with an error
Execute external program done
Programming arduino failed
Programming arduino done
Stuntteam
Site Beheer
Re: Rflinkloader fault
#2 Post by Stuntteam » 26 Feb 2019, 00:13
are you sure all files from the archive are copied?
derksuh
#3 Post by derksuh » 26 Feb 2019, 21:18
Unpacked the folder again, and now it is working.
Didn’t think about doing that before.
PeJeWe
#4 Post by PeJeWe » 09 Jan 2023, 21:29
Bij het (her)programmeren van mijn bordje krijg ik de volgende melding:
Debug mode activated
Programming Arduino:
Port COM4
Filename G:\Downloads\RFLink_v1.1_r48\RFLink.cpp.hex
Serial port test:
Serial port ok
param: -p atmega2560 -c stk500v2 -P \\.\COM4 -b 115200 -U flash:w:"G:\Downloads\RFLink_v1.1_r48\RFLink.cpp.hex":i
Exitcode 1
Heb alle bestanden uitgepakt in 1 map.
Het wordt door windows 10 als "Arduino Mega 2560 (COM4) herkend.
Ook de loader als "uitvoeren met admin rechten geprobeerd.
nog ideen?
update:
is de melding die ook nog krijg
PeJeWe
#5 Post by PeJeWe » 11 Jan 2023, 19:52
I have managed to get it working again by uninstalling the Arduino Mega 2560 windows driver in the windows device manager.
Reinstalled the arduino board.
Restart the RFLink loader and upload/install the RFLink.cpp.hex file.
After that it was up and running again.
