hi, after some investigation...
the iskra meter plugin is - as far as i know - "passive mode" - so the power meter has to transmit OBIS codes by itself - without any external transmission to power meter /using only RX phototransistor/
so you can't use it to get data from any other power meter, which transmits data only after being asked to do so, like here:
Baudrate: 300 bps, 7 bits, parity even, 1 stop bit
Send: /?!<CR><LF> (wake-up and sign-on)
Receive: /XXX5YYYYY<CR><LF> (XXX is the manufacturer ID; YYYYY is the meter ID; 5 is the new baudrate = 9600 bps)
Send: <ACK>050<CR><LF> (send ack; reading mode)
Baudrate: 9600 bps, 7 bits, parity even, 1 stop bit
Received: C.1(201236731.0(01:39 25-08-18)
1.8.1(0004398506*Wh)
1.8.2(0000000000*Wh)
1.8.3(0008198809*Wh)
1.8.4(0000000000*Wh)
1.8.5(0000000000*Wh)
1.8(0012597315*Wh)
2.8(0000000000*Wh)
D
source:
https://forum.mysensors.org/topic/9673/ ... gy-meter/4
my programming skills are very limited, so i need help from someone, who can help in writing such plugin - the good news are, that every power meter send this data in same format, so if such a plugin will be developed - we can read data from any power meter - they transmits much more than those 3 datas given in iskra plugin , there are almost 100 of obis codes
anyone could help? i can pay someone to code it, i'm sure that I'm not the only one ....
at least I hope so
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
