Have someone for sharing eagle files for Rflink for all RF modules?
Something like this https://www.nodo-shop.nl/nl/rflink-gate ... enten.html but also with:
NRF24L01 - MiLight / Applamp / Limitless Led support
CC2500 - 2.4 Ghz: Philips Living Colors / Ikea Ansluta support
Regards,
MiKa
RF link new PCB
Re: RF link new PCB
I think that this files are "not for share"
I am also interested if someone can share them...
Re: RF link new PCB
There is now a PCB design available for an RFLink shield in the EasyDomoticz forum:
https://easydomoticz.com/forum/viewtopic.php?t=4068
I built the second (larger) version with the two 433MHz RX/TX and antennas and the nrf24l01. As my arduino mega has already an esp8266 directly on the mega board, I didn't use the ESP-01.
The 433MHz RX/TX and the NRF24 are working just fine so far.
Re: RF link new PCB
I also built the shield with the ESP-01 and it works fine with one caveat : the pcb versions available for download forgot to connect the 3V3, 5V and GND pins of the level shifters for the ESP. I manually soldered some wires torn the voltage regulators to make it work just fine. I also connected the 5V of the ESP's regulator directly to the other regulator's 5V input, so I draw 5V for the esp from the arduino rather than from a second micro USB power supply...
Now the shield works fine, in particular together with my new ESPEasy RFLink to MQTT bridge plugin (PR submitted to the plugin playground)
