RFLink R48 available
Information and news about RFLink development and releases
Stuntteam
Site Beheer
#1 Post by Stuntteam » 18 Oct 2017, 19:11
R48: (18/10/2017)
- New Device: British Gas RC Plus Thermostat
- New Device: Drayton Digistat +2RF Thermostat
- New Device: Worcester Bosch DT10RF Thermostat
- New Device: Danfoss TP4000 Thermostat
- New Device: Vaillant VRT 340f Thermostat
- New Device: CalorMatic 340f Thermostat
- New Device: Hager Flash Thermostat
- New Device: Thermoflash Thermostat
- New Device: Piloteco Thermostat
- New Device: Sanfil Thermostat
- New Device: Monomat Thermostat
- New Device: Micromat Thermostat
- New Device: Monotron Thermostat
- New Device: Mémoprog RF Thermostat
- New Device: Calidou Plus Thermostat
- New Device: Radiafonte II Thermostat
- New Device: Bellagio II Thermostat
- New Device: Verplus Thermostat
- New Device: Palatino Thermostat
- New Device: Verlys Evolution Thermostat
- New Device: Melody Evolution Thermostat
- New Device: Millenium Triphasé Thermostat
- New Device: Sensual SAS Thermostat
- New Device: Sensual Bains Thermostat
- New Device: Athena Millenium Thermostat
- New Device: Athena Plenitude Thermostat
- New Device: Brel (and compatible) light switch
- New Device: Beurer BG64 (and possibly BF100) scales
- New Device: Falmec hoods
- Added: support for X10 Marmitec DS90/DS91 tamper switch
- Fixed: Milight color issue
- Fixed: Milight brightness issue
- Fixed: Milight RGB-CCT pairing made easier with pair/unpair commands
- Fixed: Milight CRC calculation on some of the protocol versions
- Fixed: Improved Kerui D025/D026 handling
- Fixed: Improved Mertik filtering
- Fixed: bug with Europe switchset unit numbers
- Fixed: Corrected TFA timing
- Fixed: Improved Cresta packet filtering
http://www.rflink.nl/blog2/
data
Re: RFLink R48 available
#2 Post by data » 30 Oct 2017, 11:24
How have you improved Kerui D025/D026 handling?
What does one have to do in order to get consistent results?
Stuntteam
Site Beheer
#3 Post by Stuntteam » 30 Oct 2017, 20:35
With the devices in hand..
They produce consistent results now.
data
#4 Post by data » 30 Oct 2017, 21:21
What result is consistent? how is it supposed to be recognized? As eurodomest or ev1527?
Since even with r48 i still don't get a correct reading :(
Stuntteam
Site Beheer
#5 Post by Stuntteam » 30 Oct 2017, 23:58
Make a debug log of your device(s). and mail that to me..
data
#6 Post by data » 31 Oct 2017, 10:39
You have mail...
mrdanne
#7 Post by mrdanne » 17 Nov 2017, 12:29
Anyone heard a solution for the Kerui sensors with R48?
Stuntteam
Site Beheer
#8 Post by Stuntteam » 18 Nov 2017, 00:37
It was tested with actual devices and should work for most.
There might be an additional feature for R49
data
#9 Post by data » 22 Nov 2017, 23:41
So what do you suggest for the moment? Wait for R49 or try something else?
Jazzle
#10 Post by Jazzle » 04 Apr 2018, 22:23
Dear Stuntteam, is there already an idea of when R49 will be released? (To stop me from fanatically checking the forum and nemcon every day :? )
Domoticz @ Raspberry Pi 3 - RFXcom @ 433MHz - RFLink @ 868MHZ - ESP8266
akasma74
#11 Post by akasma74 » 18 Apr 2018, 11:57
mrdanne wrote: 17 Nov 2017, 12:29 Anyone heard a solution for the Kerui sensors with R48?
nope. I emailed a debug log from one of my KERUI sensors to the developers, but haven't heard anything back.
perhaps they are still extremely busy.. :\
MsG
#12 Post by MsG » 25 May 2018, 15:26
I get the feeling the project is becoming more and more in a hibernation mode. Too bad, because many people use it. Unfortunately the latest releases the software stopped being open source, so we can't fork it or improve it ourselves.
Stuntteam
Site Beheer
#13 Post by Stuntteam » 26 May 2018, 01:02
We are still working on it.. just not going crazy with releases.
Milifax
#14 Post by Milifax » 21 Aug 2018, 13:15
No update for almost a year now. That's not much.
Why doesn't this project go open-source again? Wasn't it in the past?
For sure it will help development take off again.
Stuntteam
Site Beheer
#15 Post by Stuntteam » 21 Aug 2018, 14:27
Asked and answered before.. there will be updates when needed.
In the mean time we are improving and testing the code.
Milifax
#16 Post by Milifax » 22 Aug 2018, 15:01
Stuntteam wrote: 21 Aug 2018, 14:27 Asked and answered before.. there will be updates when needed.
Could you direct me to the answer then? Can;t find it, maybe my bad.
What is the reason to not go open-source with this project?
Stuntteam
Site Beheer
#17 Post by Stuntteam » 22 Aug 2018, 19:59
The framework is open-source and thus available, it is all you need for plugin development.
However, the number of contributions can be counted on one hand. This obviously means there is no need for it.
The full sources are semi public, those who need it have access to it.
Milifax
#18 Post by Milifax » 24 Aug 2018, 14:23
Stuntteam wrote: 22 Aug 2018, 19:59 The framework is open-source and thus available, it is all you need for plugin development.
How can you explain this development and comments made in their post by not being able to get the latest source?
viewtopic.php?f=9&t=5730
What is the reason? I truly don't understand why one doesn't want this sw being developed in a faster pace.
Don't get me wrong, I very much like what you did (developing rflink), but I'm a big fan of open-source development as well. Just curious why these decisions are made.
Stuntteam
Site Beheer
#19 Post by Stuntteam » 24 Aug 2018, 14:38
It has nothing to do with liking or disliking open source.
Alternative versions makes development much harder for us due to unknown/unwanted changes in the code affecting timing etc.
So it is more like quality control. It is one of the reasons we put a limitation on the distribution of the source code.
The mentioned initiative is not supported by us. We are working on ESP versions and will release when they are mature enough.
The post has been wiped to avoid confusion.
Milifax
#20 Post by Milifax » 24 Aug 2018, 16:40
Stuntteam wrote: 24 Aug 2018, 14:38 It has nothing to do with liking or disliking open source.
Too bad you look at it that way. So many other projects show it doesn't work like you say it would when sharing open-source (hard- and software).
Wiping the post is the worst way of dealing with new development in my opinion. Moving it to another setions maybe, but deleting it?!
However, I don't have the feeling you're open to any discussion, so we will leave it with this.
Looking forward to new releases though. Hope they will arrive soon with lots of new supported devices and improvements.
Good luck with development in the future.
Stuntteam
Site Beheer
#21 Post by Stuntteam » 28 Aug 2018, 20:37
Milifax wrote: 24 Aug 2018, 16:40 Wiping the post is the worst way of dealing with new development in my opinion.
Releasing under the RFlink name and posting about it in the announcements forum is in my opinion disrespectful.
If anyone wants to change my mind or tell me I am an ass then do so via PM or email.. (frankzirrone@gmail.com)
However, we are not going to escalate this any further out here!
