I'm trying to automate the heating control of our pool. When connecting two flow sensors there is currently a problem because the measured value of one of the flow sensors is inconsistent or incorrect.
The first sensor connected to GPIO14/D5 works. The second sensor which is connected to GPIO13/D7 supplies incorrect measured values at the same flow which are always too low by a factor of 2 - 4. If I swap the connections of both sensors then the sensor which is connected to GPIO14/D5 will always work properly. I have already tried to connect the second sensor to GPIO12/D6, but also the same error there. Both sensors work perfectly and the signal at GPIO has perfect rectangular shape 0/3.3V.
Is there any problem if a generic pulse counter is connected to GPIO13/D7 or GPIO12/D6, or why does this not work?
The flow sensor is: https://de.aliexpress.com/item/DN25-pip ... 17688.html
The adjustment to the 3,3 Volt level i have done with this circuit for each flow sensor:
The software is "ESPEasy_mega-20180818 Normal":
Problem with two "generic pulse counter"
Re: Problem with two "generic pulse counter"
Have you also tested to run only one sensor on the pins that now give the wrong value?
In each case only that flow sensor shows correct values which is connected to GPIO14/D5. At the expected water flowrate up to 50 liters/min there should be a pulse rate of 288 Hz - Pulse (Hz) = [4,8 * Flowrate Q (liter/min)].
On GPIO14/D5 this works fine, but GPIO13/D7 or GPIO12/D6 only counts a fraction and wrong. Unfortunately, no such restriction is mentioned here in the wiki.
Because in my circuit GPIO2/D4 is occupied with 3 temperature sensors and GPIO4/D2 and GPIO5/D1 is occupied by the I2C-interface, there is probably no further possibility to connect my two flow sensors.
OK, I measure the flowrate alternately. With a small relay, I turn each 1 flow sensor on the input GPIO14/D5 - problem solved
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
