Hi Guys,
This issue drove me bonkers this weekend. I really hope you can help.
It sounds so simple: I have 3 doors, so I have 3 (identical) door switches. All of them work. I added and configured the first 2 switches as devices with ease (GPIO 00 & GPIO 02). No problems there.
When I try to add the third switch as device, I won't work. I can add the device (same configuration as the first 2), but it does NOT register any switching (1 or 0). I picked GPIO 16, just to be sure the pin did not have multiple functions (since I'm a noob). No luck. So, the trial & error began: I tried all the other GPIO pins, without any luck. What do I miss?
No, the switch is definitely not broken. I switched it around with the others, and that worked. Except that the 3rd device wouldn't not register any switching.
I'm running R120, since I flashed it flash.cmd found on this website.
Thanks in advance!
Weird issue: can't use more than 3 switches - WeMos D1 MiniPro
Re: Weird issue: can't use more than 3 switches - WeMos D1 MiniPro
I've even 8 switches on the same device perfectly working so that's defintely possible...
Try to switch to the latest build or at least to R148.
go for R147 but you can try as well latest 2.0 build...
Users browsing this forum: Bing [Bot] and 1 guest
