Hi all,
i have bought a switch from aliexpress with the ev1527 chip in it.
The device gets recognized in rflink and i can control it.
The problem seems that i can only send a toggle command and not a specific on or off signal e.g.:
If the switch is off and i send the off command it will turn on, is this normal for this chip or should i be able to send the off command anyway and it should stay off?
I hope i made myself clear.
Best regards,
William
ev1527 on and off commands
Re: ev1527 on and off commands
This is not really useful for home automation systems since you will never know what state the device is in.
There are plenty of others that have proper distinctive ON and OFF commands.
You should probably tell others what set it is so that people can stay away from it.
Thank you for your answer.
I already thought so.
Now i have ordered the sonoff t1 eu version.
To see if that one works ok.
Best regards,
William
Best regards,
William
Users browsing this forum: No registered users and 50 guests
