jme
#1
Post
by jme » 17 Apr 2018, 15:00
Anyone know if this soil moisture sensor is compatible with ESP easy ?
How do i have to set it up ?
Same for this water level sensor ?
Thx in advance
toffel969
#2
Post
by toffel969 » 17 Apr 2018, 16:33
For the first one a definite yes. You can use the analog output to adc or the digital to any other gpio. The threshold is set up with the poti.
Post
by grovkillen » 18 Apr 2018, 20:49
I think many use the fork soil sensor incorrectly (don't hold this against me if I'm wrong, I don't have one myself) by letting them operate 24/7. The DC current will make the cathode loose the metallic part fairly fast if operated 100% of the time. I would suspect the life time to increase if you only let them run for lets say 30 seconds twice an hour?
toffel969
#5
Post
by toffel969 » 18 Apr 2018, 22:22
grovkillen wrote: ↑18 Apr 2018, 20:49
That would be preferable indeed. With task run, there should actually be a way to achieve that with rules.
However, I replaced the fork of this sensor by a stainless steel one, lasts for 9 months already without visible corrosion. It's an "ok" solution.
jme
#6
Post
by jme » 19 Apr 2018, 14:29
Thx for your answers
Which device type do i have to choose in Esp easy ?
toffel969
#7
Post
by toffel969 » 19 Apr 2018, 16:19
jme wrote: ↑19 Apr 2018, 14:29
Analog input.
https://www.letscontrolit.com/wiki/index.php/Analog
jme
#8
Post
by jme » 24 Apr 2018, 23:01
Yes that works
One more question if i put the soil moisture sensor in water i get a value of 326.
If i remove it from water i havea value of 960.
how cani convert it to percent ? 100% wet, 0%dry ?
jme
#9
Post
by jme » 24 Apr 2018, 23:54
if i want to use the digital input, wich device type do i have to set up in espeasy?
Post
by grovkillen » 25 Apr 2018, 06:10
A switch which it essentially is then, high signal when the level is above the set level (adjusted by the potentiometer).
Post
by grovkillen » 28 Apr 2018, 11:56
Cool, let's hope the new version cost about the same.
dynamicdave
#13
Post
by dynamicdave » 29 Apr 2018, 09:39
I use the first version of the mositure sensor.
I don't use the digital output. I use the voltage or analogue output.
The voltage output connects to the analogue input on an ESP8266 (Wemos D1 Mini).
I've mounted the Wemos D1 Mini on a small breadboard and routed the +3v3 for the moisture sensor via a transistor (that acts as switch).
The ESP8266 talks to Node-Red via MQTT which means I can send a message to turn-on the transistor (and power-up) the moisture sensor for a few seconds every 15-minutes or so.
Cheers from Dynamic Dave
