taskvalueset and rules trigger.
leel1967l
#1 Post by leel1967l » 25 Mar 2018, 12:29
Does taskvalueset command triggers a rule?
I am having the following issue:
I created a dummy task (name=dummy, value=t1, task number 1) and the following rule:
on [dummy#t1] do
  ..do something ..
but if I fire the command
taskvalueset,1,1,100
in the rules, the first rule is not triggered.
Wemos D1
Firmware: mega-20180324
Re: taskvalueset and rules trigger. Bug?
#2 Post by grovkillen » 25 Mar 2018, 13:03
That's by design. To trigger the rule you need to add a TaskRun after the TaskValueSet.
TaskRun,<task/device nr>
Read more here: https://www.letscontrolit.com/wiki/inde ... _Reference
leel1967l
#3 Post by leel1967l » 25 Mar 2018, 13:16
ok thanks.
leel1967l
#4 Post by leel1967l » 25 Mar 2018, 14:32
grovkillen wrote: 25 Mar 2018, 13:03 That's by design. To trigger the rule you need to add a TaskRun after the TaskValueSet.
something is still not right.
Here is the rule:
on task1 do
  taskvalueset,1,1,%eventvalue%
  taskRun,1
on [dummy#t1] do
  oled,2,1,S1=[dummy#t1]
  oled,4,1,received
  event,zone1trigger
Here is how I call it (from another UNIT):
sendto 16,event,task1=[rotary#counter]
Here is the log:
9376109 : EVENT: task1=29
9376146 : ACT : taskvalueset,1,1,29
9376157 : ACT : taskRun,1
9379297 : WD : Uptime 155 ConnectFailures 0 FreeMem 13568
9409297 : WD : Uptime 156 ConnectFailures 0 FreeMem 13568
9413423 : EVENT: Clock#Time=Sun,14:30
But the code triggered by the value changed is not executed.
toffel969
#5 Post by toffel969 » 26 Mar 2018, 00:33
leel1967l wrote: 25 Mar 2018, 14:32
Here is the rule:
on task1 do
  taskRun,1
on [dummy#t1] do
  oled,4,1,received
  event,zone1trigger
Here is the log:
I think I see a syntax error, should it not be:
on task1 do
  taskRun,1
on dummy#t1 do
  oled,4,1,received
  event,zone1trigger
leel1967l
#6 Post by leel1967l » 26 Mar 2018, 00:38
You are right!
You can't imagine how many times I have looked at the code without noting it...
Will try tomorrow.
Users browsing this forum: Bing [Bot] and 1 guest
