I still have some devices (doorbell, weather station, ..) not working with rflink, protocol unknown or unrecognized.
Is there a way to send custom raw data packet via RFLink ???
With this kind of feature, it should be easy to trigger a device with a unknown protocol (with fixed code).
Because I know exactly what I have to send. (pulse length, timing, repeat, ...)
I do that with a 2nd TX433 but that's pity to have to duplicate the transmitters in my box
2 transceivers (same frequency) very close to one is not the good way I think, moreover I can not disable the RX on RFLink board when the other one TX.
Thanks for the great work.
Custom packet needed pse
Re: Custom packet needed pse
As far as I know, you can do that and there are a lot of guidelines in the Internet that described similar problem. Just try to Google it better. Or you already found the solution?
Users browsing this forum: Majestic-12 [Bot] and 2 guests
