I have fhem as controller entered.
I had to change the port, but when submitting, the old port is retained.
I can not delete the controler.
How can I update the port settings?
Thanks T
controller port update not stored
Re: controller port update not stored
I tried it here and it seems to work just fine.
However, the code I run here has the latest fixes.
You can clear the controller by setting the protocol to "standalone".
thanks
setting to standalone and back solved it.
thanks
Users browsing this forum: Ahrefs [Bot] and 1 guest
