AP mode to wifi switch mode
riker1
#1 Post by riker1 » 27 Dec 2017, 17:50
the esp is still booting into ap mode. but I want the normal wifi mode.
How can this be changed?
enesbcs
Re: AP mode to wifi switch mode
#2 Post by enesbcs » 27 Dec 2017, 18:37
riker1 wrote: 27 Dec 2017, 17:50 Hi
If the ESPEasy are unable to join to the WIFI, that you specify it defaults to AP mode. Try to place the ESP near the AP, and retry.
Hint: Wifi name and password is also case sensitive. :)
riker1
#3 Post by riker1 » 27 Dec 2017, 19:12
ok thanks understood, will check.
riker1
#4 Post by riker1 » 28 Dec 2017, 16:07
thanks it worked.
Is it possible to deactivate the AP fallback mode?
thanks T
vader
#5 Post by vader » 28 Dec 2017, 17:01
For what should it be good for? If the AP is in reach again, the ESP connects to it automatically.
#6 Post by TD-er » 28 Dec 2017, 17:09
@vader:
From a security standpoint, could disabling the AP fallback be a good idea. Like suggested in this issue: https://github.com/letscontrolit/ESPEasy/issues/663
enesbcs
#7 Post by enesbcs » 28 Dec 2017, 18:20
riker1 wrote: 28 Dec 2017, 16:07 Is it possible to deactivate the AP fallback mode?
Possible. There are some solutions, however not so not elegant: :)
viewtopic.php?f=6&t=2846#p21857
vader
#8 Post by vader » 28 Dec 2017, 19:17
That's a joke of 10 minutes programming....
#9 Post by TD-er » 28 Dec 2017, 23:27
@vader: It surely isn't a big code change. Discussion about what's wanted is 90% of the work with features like these :)
For instance how to re-enable the AP? :) (that will add another 5 minutes of programming)
