Plugin _P015_TLS2561 - division by zero possible
beegee
#1 Post by beegee » 03 Dec 2015, 15:04
I am using the TLS2561 plugin and stumbled over following problem:
When the sensor is completely covered (no light at all) a division by zero exception can occur.
The problem is in line 293 of the _P015_TLS2561.ino file.
if( ch0/ch1 < 2 && ch0 > 4900)
If there is no light at all, ch1 will be 0. This exception is not caught. Possible change:
  // ch1 out of range. the lux is not valid in this situation.
  if (ch1 == 0) {
  	return -1;
  // ch0 out of range, but ch1 not. the lux is not valid in this situation.
  if( ch0/ch1 < 2 && ch0 > 4900) {
Hope this helps!
Users browsing this forum: Google [Bot] and 37 guests
