I activated "timestamps" in RFLink Loader and sometimes timestamps are inserted in the middle of the packets.
Below a full log of packets (about 5 minutes).
In the first part, the sensor is at about 3 meters => not decoded.
In the second part, the sensor is at about 10 centimeters => decoded.
I have a "Xiron" temperature sensor perfectly decoded at about 10 meters through walls.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R46;
10;version;
20;01;VER=1.1;REV=46;BUILD=0c;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
10;rfudebug=on;
20;04;RFUDEBUG=ON;
20;05;DEBUG;Pulses=35;Pulses(uSec)=270,420,360,480,300,480,330,510,270,510,270,420,360,450,300,480,360,390,360,480,270,450,360,450,330,480,300,510,300,450,330,510,330,450,150;
20;06;DEBUG;Pulses=66;Pulses(uSec)=480,3930,420,3900,420,1860,420,3930,420,1830,390,1860,390,3960,390,1860,360,3960,360,1890,360,3960,390,1860,360,3960,390,3930,390,3960,360,1890,360,1920,330,1920,360,1890,330,1920,330,1920,300,3990,330,3990,330,1920,330,3990,330,3990,330,1920,330,1920,330,1920,330,3990,330,3990,330,4110,330,6990;
20;07;DEBUG;Pulses=48;Pulses(uSec)=420,1800,330,3750,360,1800,360,3960,360,3960,360,3960,390,1860,360,1890,360,1890,360,1890,360,1890,360,1890,360,3960,360,3960,360,1890,360,3960,390,3960,390,1860,390,1860,360,1890,360,3960,390,3960,390,4050,390,6990;
20;08;DEBUG;Pulses=58;Pulses(uSec)=450,1770,360,1770,360,3750,360,1860,390,3930,390,1860,360,3960,390,1860,360,3960,390,3930,390,3960,390,1860,390,1860,360,1860,390,1860,390,1890,360,1890,360,3960,390,3960,390,1860,360,3960,390,3960,390,1860,390,1860,390,1860,390,3960,390,3930,390,4050,390,6990;
20;09;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,360,1770,390,3960,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1890,360,1860,390,1890,360,3960,390,3960,390,1890,360,3930,390,3930,390,1860,390,1890,390,1890,360,3960,390,3930,390,4080,390,6990;
20;0A;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,390,3870,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,360,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3930,420,1830,390,3930,390,3930,390,1860,390,1890,390,1860,360,3930,390,3930,390,4050,420,6990;
20;0B;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1740,360,3780,420,1860,390,3930,390,1860,360,3960,390,3930,390,3960,390,1860,390,1860,390,1860,390,1890,360,1890,360,1860,390,3960,360,3960,390,1860,390,3930,390,3960,390,1860,390,1890,360,1860,390,3930,390,3930,390,4050,390,6990;
20;0C;DEBUG;Pulses=38;Pulses(uSec)=420,3750,390,1740,390,3750,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,420,1830,390,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3930,390,1860,390,3810;
20;0D;DEBUG;Pulses=62;Pulses(uSec)=480,1830,390,3930,390,1860,390,1860,390,3930,390,1890,360,3960,360,1860,390,3960,360,1890,390,3960,360,3960,360,3960,360,1890,360,1890,330,1950,330,1920,330,1920,330,1920,330,3990,330,3990,360,1890,330,3990,360,3990,330,1920,330,1920,330,1890,360,3990,330,3990,360,4080,360,6990;
20;0E;DEBUG;Pulses=50;Pulses(uSec)=450,3750,330,1800,360,3810,390,1860,360,3960,390,3930,390,3930,390,1890,360,1890,390,1890,360,1890,360,1890,330,1920,360,3930,390,3960,390,1860,390,3960,390,3930,390,1890,360,1860,360,1890,360,3960,360,3960,390,4080,390,6780;
20;0F;DEBUG;Pulses=56;Pulses(uSec)=450,1770,360,3750,390,1740,360,3930,420,1830,390,3930,390,1860,390,3960,390,3930,390,3930,390,1860,390,1860,360,1890,360,1860,390,1890,360,1860,360,3960,390,3960,360,1860,390,3960,390,3930,390,1860,390,1890,360,1890,360,3960,390,3930,390,4050,390,6990;
20;10;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,360,1860,360,3960,390,1860,390,3930,420,3930,390,3930,420,1860,390,1890,360,1860,390,1860,360,1860,390,1860,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,360,1890,360,1890,360,3930,390,3930,390,4050,390,6990;
20;11;DEBUG;Pulses=54;Pulses(uSec)=420,3750,360,1770,360,3840,390,1860,390,3930,420,1860,360,3960,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,360,1890,360,1860,360,3990,360,3930,390,1860,390,3930,390,3960,390,1860,390,1860,360,1860,390,3960,390,3960,390,3990,450,6990;
20;12;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,360,3780,420,1860,390,3930,360,1860,390,3960,390,3930,390,3930,390,1860,360,1860,390,1860,390,1860,390,1860,390,1890,390,3930,390,3960,390,1860,390,3930,390,3930,390,1860,390,1860,360,1860,390,3960,360,3960,360,4080,390,6990;
20;13;DEBUG;Pulses=54;Pulses(uSec)=420,3750,360,1770,360,3780,390,1860,390,3930,390,1860,390,3930,390,3930,420,3900,390,1860,390,1860,390,1860,360,1890,390,1860,390,1860,360,3960,390,3960,390,1860,390,3930,420,3900,420,1860,360,1860,390,1890,360,3960,390,3960,390,4050,390,6990;
20;14;DEBUG;Pulses=101;Pulses(uSec)=270,270,480,330,570,210,450,360,390,390,420,360,390,390,390,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,450,330,420,360,420,360,450,330,420,360,420,360,450,330,450,330,900,870,930,840,420,330,450,330,420,360,450,360,900,360,420,390,390,840,930,840,930,330,450,330,450,330,450,810,960,300,480,810,960,300,480,780,510,270,990,270,510,720,1050,690,660,60,1170,30,1710,90,720,60,720,60;
20;15;DEBUG;Pulses=28;Pulses(uSec)=150,960,330,480,360,480,270,450,810,960,330,510,780,930,330,480,300,480,780,960,810,480,330,450,330,930,330,510;
20;16;DEBUG;Pulses=62;Pulses(uSec)=480,1830,420,3930,360,1890,390,1860,360,3960,390,1860,390,3930,390,1890,360,3960,360,1890,330,3990,330,3960,360,3960,360,1890,360,1890,330,1890,330,1920,330,1890,330,1920,330,4020,330,3990,330,1920,330,3990,330,3990,360,1890,330,1920,330,1920,330,3990,360,3960,360,4110,330,6990;
20;17;DEBUG;Pulses=50;Pulses(uSec)=420,3750,360,1800,330,3840,360,1860,390,3960,390,3960,360,3960,360,1890,360,1890,360,1890,360,1890,360,1890,360,1890,360,3960,360,3930,390,1860,390,3930,390,3960,390,1860,360,1860,360,1890,360,3960,390,3960,390,4050,390,6990;
20;18;DEBUG;Pulses=56;Pulses(uSec)=450,1770,360,3720,390,1770,390,3900,390,1860,390,3930,390,1890,360,3960,360,3960,360,3960,390,1860,360,1860,390,1860,360,1890,360,1890,390,1860,360,3960,390,3930,390,1860,360,3960,390,3960,390,1860,390,1860,360,1890,360,3960,390,3930,390,4080,390,6990;
20;19;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,3750,390,1830,390,3930,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,360,1890,390,1860,390,1860,360,1890,360,3960,390,3960,390,1860,390,3960,390,3930,390,1860,390,1890,360,1860,390,3960,390,3960,420,4020,390,6990;
20;1A;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,360,3870,390,1860,390,3930,390,1860,390,3930,390,3930,390,3960,390,1860,420,1830,390,1860,360,1860,390,1890,360,1890,360,3930,390,3930,390,1860,390,3930,390,3930,420,1860,390,1890,360,1890,360,3960,390,3960,390,4020,420,4740;
20;1B;DEBUG;Pulses=56;Pulses(uSec)=300,1770,360,3720,390,1770,390,3870,390,1860,390,3930,390,1890,390,3930,390,3930,420,3930,420,1830,390,1860,360,1860,390,1860,390,1890,360,1890,360,3960,390,3960,390,1860,390,3930,390,3960,390,1860,360,1860,390,1890,390,3930,390,3930,390,4080,390,6990;
20;1C;DEBUG;Pulses=52;Pulses(uSec)=420,1770,390,3720,360,1860,390,3930,420,1860,390,3930,420,3930,390,3960,390,1860,390,1860,390,1890,360,1860,360,1890,360,1890,390,3930,390,3930,390,1860,390,3960,390,3930,390,1860,420,1860,360,1890,390,3960,390,3930,390,4050,420,6990;
20;1D;DEBUG;Pulses=26;Pulses(uSec)=450,30,360,330,420,360,420,390,360,450,330,480,300,450,330,510,270,480,330,420,330,510,300,510,270,510;
20;1E;DEBUG;Pulses=52;Pulses(uSec)=390,450,330,420,360,450,300,480,330,450,300,510,300,420,840,930,330,450,780,960,780,1020,750,960,330,450,810,480,300,480,330,960,330,450,360,480,300,450,780,930,360,420,810,930,330,450,390,390,840,930,810,510;
20;1F;DEBUG;Pulses=168;Pulses(uSec)=720,300,450,330,450,330,420,360,420,360,420,360,360,390,390,390,390,390,390,390,390,450,330,420,360,420,360,420,360,420,330,450,330,420,360,420,360,450,330,450,330,450,330,450,330,450,330,900,870,900,840,420,330,450,360,420,330,420,360,930,360,420,390,390,840,930,840,930,360,420,360,420,360,420,810,930,330,450,810,960,300,480,780,510,270,990,300,510,750,1020,720,570,180,1080,690,1110,180,630,150,630,270,1530,120,660,600,1140,150,660,630,660,120,1110,180,660,120,630,150,630,150,630,180,600,180,630,660,1080,180,600,210,570,210,600,180,600,660,1080,180,600,180,570,210,570,210,570,240,570,690,1080,210,570,210,570,210,600,690,1080,210,600,690,570,180,1080,210,570,720,1080,690,6990;
20;20;DEBUG;Pulses=62;Pulses(uSec)=450,1860,390,3930,390,1860,360,1890,360,3960,390,1860,360,3960,360,1890,330,3990,360,1890,330,3990,330,3990,360,3960,360,1860,360,1890,360,1890,330,1950,300,1950,330,1920,330,3990,330,3990,330,1920,330,3990,330,3990,330,1920,360,1890,330,1920,360,3960,390,3990,360,4080,360,6990;
20;21;DEBUG;Pulses=50;Pulses(uSec)=420,3750,330,1800,360,3810,390,1860,390,3960,390,3930,390,3960,360,1860,360,1890,360,1860,360,1890,360,1890,360,1890,360,3960,360,3960,390,1890,360,3960,390,3960,390,1860,390,1890,360,1860,360,3960,390,3960,390,4050,390,6990;
20;22;DEBUG;Pulses=48;Pulses(uSec)=450,1770,360,3930,390,1860,360,3960,420,1860,360,3960,390,3960,360,3930,390,1860,390,1860,390,1890,360,1860,390,1860,360,1860,360,3960,390,3930,390,1860,390,3930,390,3960,390,1860,390,1860,390,1860,390,3930,390,2310;
20;23;DEBUG;Pulses=64;Pulses(uSec)=450,3720,420,1740,390,3900,390,1830,420,1860,390,3930,390,1860,390,3930,390,1890,390,3930,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1860,360,1890,390,1860,390,1890,390,3930,390,3930,390,1860,420,3930,390,3930,390,1830,390,1860,390,1890,390,3930,390,3930,390,4050,390,5250;
20;24;DEBUG;Pulses=48;Pulses(uSec)=450,1770,390,3810,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,360,3960,390,1890,390,3930,390,3930,390,1860,390,1860,390,1860,360,3960,390,3930,420,4020,420,570;
20;25;DEBUG;Pulses=66;Pulses(uSec)=480,3930,420,3900,390,1860,390,3960,390,1860,360,1890,360,3960,390,1860,390,3930,360,1890,390,3930,390,1860,390,3960,390,3930,450,3900,390,1860,390,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,360,1890,360,3960,390,3930,420,4080,390,5100;
20;26;DEBUG;Pulses=34;Pulses(uSec)=390,360,480,300,390,390,420,360,390,420,330,480,330,420,330,480,300,510,300,510,270,420,330,510,270,540,240,510,270,600,180,480,300,510;
20;27;DEBUG;Pulses=36;Pulses(uSec)=750,510,300,450,300,990,360,420,780,510,270,990,330,450,300,480,780,960,330,480,270,480,330,450,330,480,330,480,270,480,300,480,300,510,300,450;
20;28;DEBUG;Pulses=40;Pulses(uSec)=360,420,330,420,300,420,750,930,300,420,750,900,300,480,270,480,780,930,780,510,270,480,300,960,300,450,360,450,300,480,300,480,300,480,390,390,810,960,780,6990;
20;29;DEBUG;Pulses=62;Pulses(uSec)=480,1860,420,3930,390,1860,390,1860,390,3930,390,1860,390,3960,360,1890,360,3960,360,1890,360,3960,360,3960,360,3960,360,1890,360,1890,360,1920,330,1920,330,1920,330,1950,300,3990,330,3990,330,1920,330,3990,330,3990,330,1920,330,1920,330,1920,330,3990,330,3990,330,4110,360,6990;
20;2A;DEBUG;Pulses=50;Pulses(uSec)=420,3750,330,1800,330,3840,390,1890,360,3960,360,3960,390,3930,360,1860,360,1890,360,1890,330,1890,360,1890,360,1890,390,3960,360,3930,360,1860,390,3960,360,3960,390,1860,390,1860,360,1890,360,3960,360,3960,390,4050,390,6660;
20;2B;DEBUG;Pulses=56;Pulses(uSec)=450,1740,360,3750,360,1770,360,3930,390,1860,390,3930,420,1860,390,3930,390,3930,390,3930,420,1860,420,1830,390,1860,390,1890,390,1860,390,1890,360,3960,390,3960,360,1890,360,3960,390,3930,390,1860,420,1860,390,1830,390,3960,390,3960,390,4050,420,6990;
20;2C;DEBUG;Pulses=52;Pulses(uSec)=420,1800,360,3750,360,1830,390,3960,390,1860,390,3930,420,3930,390,3930,420,1830,420,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1890,390,1860,390,1860,390,3960,360,3960,390,4050,390,6990;
20;2D;DEBUG;Pulses=48;Pulses(uSec)=450,1860,390,3930,390,1860,390,3930,390,3930,420,3960,390,1830,390,1860,390,1860,360,1860,360,1890,390,1860,360,3960,390,3930,390,1860,390,3930,390,3960,420,1830,390,1890,390,1860,420,3930,390,3930,390,4050,420,3930;
20;2E;DEBUG;Pulses=58;Pulses(uSec)=480,1740,360,1770,360,3870,390,1860,390,3930,390,1860,390,3930,390,1860,390,3930,390,3930,420,3900,420,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3930,390,3960,390,4050,420,6990;
20;2F;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,360,1770,390,3930,390,1860,420,3930,390,3930,390,3930,390,1860,420,1860,360,1860,390,1860,390,1860,360,1890,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1890,390,1860,390,3930,390,3930,450,4020,390,5190;
20;30;DEBUG;Pulses=168;Pulses(uSec)=660,330,480,300,450,330,450,360,420,360,390,390,390,390,390,390,390,390,390,420,360,420,390,420,390,420,360,420,360,420,360,450,330,420,360,420,360,420,360,420,360,420,360,420,360,450,330,900,870,900,870,420,360,450,360,420,360,420,360,930,330,420,360,390,840,930,840,930,330,450,330,450,330,450,840,930,330,420,810,930,330,480,780,510,300,990,300,480,780,990,750,540,240,1020,750,1020,240,540,240,570,720,1080,210,570,690,1080,180,570,660,630,150,1110,150,630,150,600,180,600,180,630,150,630,150,630,630,1110,150,630,150,630,150,630,180,600,660,1110,150,600,180,600,210,570,210,600,180,600,660,1080,210,600,210,570,210,600,660,1080,210,600,690,600,180,1080,210,600,660,1080,690,6990;
20;31;DEBUG;Pulses=62;Pulses(uSec)=480,1860,390,3930,390,1860,390,1860,390,3930,390,1890,390,3960,360,1860,360,3960,390,1890,360,3960,360,3960,360,3990,360,1890,360,1890,360,1890,330,1950,300,1950,300,1950,300,4020,300,4020,330,1950,300,4020,330,3990,330,1920,330,1920,300,1920,330,3990,330,3990,360,4110,330,6990;
20;32;DEBUG;Pulses=38;Pulses(uSec)=420,3720,360,1800,330,3840,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,360,1890,360,1860,390,1860,390,1860,360,3960,390,3930,420,1830,420,3900,390,3930,390,930;
20;33;DEBUG;Pulses=36;Pulses(uSec)=450,1860,360,1890,390,1860,360,1860,390,1890,360,1890,360,3960,420,3930,360,1890,360,3960,390,3960,390,1860,360,1860,390,1860,390,3960,360,3960,390,4050,390,6990;
20;34;DEBUG;Pulses=62;Pulses(uSec)=450,1770,360,3750,390,1830,390,1860,390,3930,390,1860,390,3960,390,1860,360,3960,390,1860,390,3960,390,3960,360,3960,390,1860,390,1860,360,1890,360,1890,360,1890,360,1890,360,3960,390,3930,390,1860,360,3960,360,3960,390,1860,390,1860,360,1860,390,3930,390,3930,360,4080,390,5460;
20;35;DEBUG;Pulses=50;Pulses(uSec)=450,3750,360,1770,360,3900,360,1860,390,3930,420,3930,420,3930,390,1860,390,1860,390,1860,390,1860,360,1860,390,1890,360,3960,390,3930,390,1860,390,3960,390,3960,390,1860,390,1860,390,1860,390,3960,390,3930,360,3990,480,750;
20;36;DEBUG;Pulses=40;Pulses(uSec)=450,3930,420,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1890,390,3900,420,3930,420,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4080,390,2520;
20;37;DEBUG;Pulses=62;Pulses(uSec)=480,1710,360,3750,390,1860,390,1860,390,3930,390,1860,390,3930,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3960,390,3960,390,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3960,390,3930,360,4080,390,6990;
20;38;DEBUG;Pulses=29;Pulses(uSec)=480,420,360,420,330,450,330,420,330,480,300,510,300,420,330,540,240,540,270,540,240,480,300,600,210,480,300,510,30;
20;39;DEBUG;Pulses=136;Pulses(uSec)=90,900,300,450,720,480,240,960,270,480,240,480,300,450,270,480,720,930,300,480,300,480,300,480,300,450,810,480,300,480,300,960,360,420,810,540,240,990,300,450,300,480,780,960,300,480,330,480,300,480,300,480,300,480,300,480,300,480,300,480,330,450,300,480,300,450,360,480,300,480,300,450,330,480,300,480,330,450,810,960,330,480,810,960,780,960,780,990,330,510,750,480,300,480,330,930,360,450,330,450,330,450,810,960,360,450,810,960,300,450,330,480,810,960,780,480,270,480,300,930,330,450,360,510,270,450,330,450,360,450,330,450,780,990,810,6990;
20;3A;DEBUG;Pulses=72;Pulses(uSec)=720,1590,420,3900,420,3930,420,3840,510,3900,420,1830,420,3930,390,1860,420,1860,360,3960,390,1860,360,3960,360,1890,360,3960,390,1890,360,3960,360,3960,360,3960,360,1890,360,1890,360,1890,360,1920,330,1920,330,1920,330,4020,330,3990,360,1920,330,3990,360,3990,360,1920,330,1920,330,1920,330,3990,360,3990,360,4110,330,6990;
20;3B;DEBUG;Pulses=46;Pulses(uSec)=300,3780,360,1770,360,3750,390,3960,360,3960,390,1860,360,1860,360,1860,390,1860,360,1890,360,1890,360,3930,360,3960,390,1860,360,3960,390,3930,390,1890,360,1890,360,1890,360,3960,390,3960,390,4080,390,6990;
20;3C;DEBUG;Pulses=58;Pulses(uSec)=450,1740,360,1770,330,3810,390,1860,390,3960,390,1830,390,3930,390,1860,360,3960,360,3960,390,3930,390,1860,390,1890,360,1890,360,1890,360,1890,390,1860,360,3960,390,3960,390,1860,390,3930,390,3960,390,1860,390,1860,390,1860,360,3960,390,3960,390,4050,390,6990;
20;3D;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,3750,360,1770,390,3930,390,1860,360,3960,390,3930,390,3930,420,1860,390,1860,390,1890,390,1860,390,1860,360,1860,390,3960,390,3960,390,1860,360,3960,390,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4050,420,6990;
20;3E;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1740,360,3870,390,1860,360,3960,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1890,390,1860,360,1890,360,3930,420,3930,360,1860,390,3960,360,3930,390,1890,360,1890,360,1860,390,3930,390,3930,420,4020,420,5940;
20;3F;DEBUG;Pulses=54;Pulses(uSec)=420,3750,390,1770,360,3840,390,1860,420,3930,390,1860,390,3930,360,3960,420,3930,390,1860,390,1860,390,1890,360,1890,360,1860,390,1860,390,3930,390,3930,360,1890,390,3900,420,3930,420,1860,390,1860,390,1890,360,3960,390,3930,360,4080,390,6990;
20;40;DEBUG;Pulses=34;Pulses(uSec)=480,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,420,3930,420,1830,420,3900,390,3930,390,1860,390,1860,360,1860,390,3930,390,3330;
20;41;Oregon TempHygro;ID=228D3;TEMP=00c1;HUM=41;HSTATUS=0;BAT=OK;
20;42;DEBUG;Pulses=130;Pulses(uSec)=330,990,300,510,270,510,300,480,300,510,780,960,330,540,240,480,330,480,270,480,810,480,300,480,330,960,390,420,780,510,300,990,300,510,270,510,780,990,300,480,300,480,270,450,300,480,330,510,270,480,300,480,300,510,330,420,330,450,330,480,300,480,300,420,330,480,150,630,300,480,330,450,780,930,330,450,840,930,810,990,780,990,240,480,780,510,300,450,360,930,330,420,330,450,360,450,780,960,360,420,840,960,300,480,330,480,780,960,810,480,270,480,330,930,330,450,330,480,330,450,330,450,330,450,360,420,840,930,810,6990;
20;43;DEBUG;Pulses=62;Pulses(uSec)=480,1860,390,3930,420,1860,390,1860,390,3930,390,1890,360,3960,360,1890,360,3960,390,1860,360,3990,330,3960,360,3990,360,1890,360,1890,330,1920,360,1920,300,1920,330,1920,330,3990,330,3990,330,1920,330,4020,330,3960,390,1890,330,1920,330,1890,360,3990,360,3960,360,4080,360,6990;
20;44;DEBUG;Pulses=48;Pulses(uSec)=450,1770,390,3810,360,1890,360,3960,390,3960,390,3960,390,1860,420,1830,390,1860,360,1890,360,1890,390,1890,360,3960,360,3960,390,1830,390,3930,390,3960,390,1860,390,1860,390,1860,420,3900,390,3960,390,4050,390,6990;
20;45;DEBUG;Pulses=52;Pulses(uSec)=480,1740,390,1740,390,3720,360,1860,390,3930,420,1860,390,3960,390,1860,390,3930,420,3900,390,3930,420,1860,360,1860,420,1860,390,1860,390,1860,390,1890,360,3960,390,3930,390,1890,390,3930,420,3930,390,1860,390,1860,390,1860,360,2460;
20;46;DEBUG;Pulses=40;Pulses(uSec)=450,3930,420,1830,420,1830,420,3930,360,1860,390,3930,420,1860,390,3930,420,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1890,390,1860,390,1860,360,1890,390,3930,390,2010;
20;47;DEBUG;Pulses=48;Pulses(uSec)=450,1860,390,3960,390,1860,390,3930,390,3930,420,3900,390,1860,360,1860,390,1860,360,1890,390,1860,330,1890,390,3930,390,3930,390,1860,390,3960,390,3960,390,1860,390,1860,360,1860,390,3930,420,3900,420,4050,420,210;
20;48;DEBUG;Pulses=26;Pulses(uSec)=480,1860,420,1860,420,1830,390,1860,360,1890,390,1890,360,3960,390,3930,390,1860,390,3930,360,3960,420,1860,390,1440;
20;49;DEBUG;Pulses=26;Pulses(uSec)=480,1860,420,1830,390,1890,390,1830,390,1860,390,1860,360,3960,390,3960,390,1830,390,3930,390,3930,390,1860,390,1020;
20;4A;Oregon TempHygro;ID=228D3;TEMP=00c2;HUM=41;HSTATUS=0;BAT=OK;
20;4B;DEBUG;Pulses=58;Pulses(uSec)=480,1860,390,1860,360,3960,390,1860,390,3930,390,1860,390,3960,360,1860,360,3960,360,3960,360,3960,360,1890,360,1890,360,1890,330,1920,330,1920,330,1950,300,3990,330,3990,330,1920,330,4020,330,3990,330,1920,330,1920,330,1920,330,3990,330,3990,330,4110,360,6990;
20;4C;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,330,1800,360,3960,390,1860,390,3960,390,3930,360,3960,390,1890,360,1890,360,1860,390,1890,360,1890,360,1890,390,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3960,420,3930,390,4080,390,6990;
20;4D;DEBUG;Pulses=45;Pulses(uSec)=30,930,240,60,1140,450,270,900,300,420,510,240,300,450,300,120,1050,900,360,480,300,450,660,120,330,480,1140,150,300,450,300,960,360,420,840,480,270,870,390,450,330,450,810,960,360;
20;4E;DEBUG;Pulses=38;Pulses(uSec)=30,30,1140,930,270,480,300,450,810,990,780,510,270,510,630,630,300,450,660,150,330,450,300,300,510,480,330,450,780,990,780,1860,360,3960,390,4080,390,6990;
20;4F;DEBUG;Pulses=44;Pulses(uSec)=450,1860,390,3930,390,3960,390,3930,420,1860,390,1860,390,1860,360,1890,360,1890,360,1890,360,3930,390,3960,390,1860,390,3930,390,3930,390,1860,390,1860,360,1890,360,3930,390,3930,390,4080,390,5430;
20;50;DEBUG;Pulses=60;Pulses(uSec)=450,3720,390,1740,390,1740,360,3930,390,1860,390,3930,390,1860,360,3960,420,1860,390,3930,390,3930,390,3930,420,1860,390,1860,360,1890,390,1860,360,1890,360,1890,360,3960,390,3960,390,1860,390,3960,390,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4050,390,960;
20;51;DEBUG;Pulses=50;Pulses(uSec)=450,3660,450,1770,360,3840,390,1860,420,3930,390,1860,360,3960,390,3900,390,3930,420,1860,390,1860,390,1860,360,1860,390,1860,360,1860,390,3930,390,3960,390,1860,390,3960,390,3960,420,1830,390,1860,390,1860,360,3960,390,2550;
20;52;DEBUG;Pulses=58;Pulses(uSec)=450,1860,390,1860,360,3960,390,1860,390,3960,390,1860,390,3930,390,1860,390,3930,390,3960,390,3930,390,1860,390,1860,390,1860,390,1860,360,1890,360,1890,390,3930,390,3930,390,1860,360,3960,360,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4050,390,6990;
