Pool temperature sensor
Hi !
I just got rflink gateway from nodo (5 days to send allready soldered device to france??? guys you rocks !)
and a pool temperature sensor very similar to this one :
https://www.amazon.fr/ASTrade-Capteur-T ... Y4AQ17FMA5
and this one:
https://www.amazon.fr/SODIAL-Thermometr ... B00SMCB912
Saddly it's not working with last (r46) firmware
I wanted to release a plugin for this hardware but don't found where to begin.
I found someone talking about rubicson protocol used with rfxcom (not sure with exact same hardware)
I saw that plugin_045.c talk about rubicson...
...that's it, don"t know what's the next step
How do you move from debug pulses to bytes/bits ? is there some tutorial ?
I know that the device can talk in 3 different chanels (I can choose chanel with integrated switch)
I saw 2 sets of pulses every time data are sent
I take some debug trace (temperature is getting warmer as I try to understand ) :
Thanks for any help
and this one:
Thanks for any help
Re: Pool temperature sensor
See PM..
It's working
Thank you
Thank you
I have one as well. Would be nice if you could pass on that information
Xai
Xai
Check your mailboxes..
The beta firmware that I received in a PM didn't help. I have emailed debug logs to the devs.
After some additional debug examples, the wonderful RFlink dev has provided a firmware that works with my pool thermometer too.
Thank you so much!
Thank you so much!
Great to hear. Can you tell me what version it is or can you provide the link to that version?
Xai
I found it Works great ... Thank you so much!
Xai
- LisaHamiltonEu
Hi, I'm looking for a pool temperature sensor, do the ones from Amazon work well? I need real reviews because I don't want to waste money. I have a difficult financial situation because of the quarantine, so I have to save on everything. Moreover, recently neighbors advised me to install solar panels to save on electricity. We also have a fountain that can be transformed and it will work by a solar water pump. By the way, here you can find the review of the best solar powered water pumps that are used for fountains and ponds. If you have already had this experience, please share your feedback.
