When compiled with #define PLUGIN_BUILD_TESTING, SendToHTTP 192.168.0.243,8080,/json.htm?type=command¶m=switchlight&idx=293&switchcmd=On does not toggle the switch in Domoticz.
When compiled with #define PLUGIN_BUILD_NORMAL, it does work as expected.
SendToHTTP problem
Re: SendToHTTP problem
Try:
#define PLUGIN_BUILD_TESTING, SendToHTTP,192.168.0.243,808,/json.htm?type=command¶m=switchlight&idx=293&switchcmd=On
Thanks for the hint.
Unfortunately, it makes no difference.
Users browsing this forum: Ahrefs [Bot] and 2 guests
