WH2A (Branded as Lacrossetechnology and Tesa Weather Pro)
wormie_dk
#1 Post by wormie_dk » 19 Jan 2017, 17:06
Would it be possible to add support for the WH2A transmitter. I purchased mine from: https://www.aliexpress.com/item/Transmi ... 0.0.Ihdr0l
But can also be seen here:
http://shop.lacrossetechnology.com.au/t ... itter.html
Log is below for temperature around 26,7 and humidity around 41 %:
10;rfdebug=on;
20;0C;RFDEBUG=ON;
20;0D;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,420,870,1380,870,420,870,390,870,1380,870,420,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;0E;DEBUG;Pulses=48;Pulses(uSec)=450,810,360,840,1320,810,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;0F;DEBUG;Pulses=100;Pulses(uSec)=60,840,1290,840,1290,840,1290,840,1350,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,390,870,420,870,390,870,390,870,390,870,1350,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1350,870,1380,6990;
20;10;DEBUG;Pulses=222;Pulses(uSec)=1410,1410,2070,660,600,2130,2070,660,600,2130,2100,660,600,2130,2070,660,2070,660,2070,660,2100,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,600,2130,600,2130,600,2130,600,2130,1350,1410,2070,660,600,2130,2070,660,630,2130,2070,660,600,2130,2070,660,2070,660,2070,660,2070,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,600,2130,630,2130,600,2130,630,2130,1350,1410,2070,660,600,2130,2070,660,630,2130,2070,660,600,2130,2070,660,2070,660,2070,660,2070,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,630,2130,600,2130,600,2130,600,2130,1350,1380,2070,660,630,2130,2070,660,600,2130,2070,660,600,2130,2100,660,2070,660,2070,660,2100,660,2070,660,2070,660,600,2130,2070,660,2070,660,600,2130,600,2130,630,2130,600,2130,600,2130,600,2130,1350,1380,2070,660,600,2130,2100,660,600,2130,2070,660,600,2130,2070,660,2070,660,2100,660,2070,660,2070,660,2070,660,600,2130,2070,660,2070,660,600,2130,630,2130,630,2130,600,2130,600,2130,600,2130,1230,6990;
20;11;Biltema;ID=0002;TEMP=00dd;HUM=32;
20;12;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,900,390,870,420,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;13;DEBUG;Pulses=48;Pulses(uSec)=360,840,360,840,360,810,390,810,360,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,420,870,1380,870,1380,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,1380,6990;
20;14;DEBUG;Pulses=98;Pulses(uSec)=1380,810,1320,810,1290,840,360,840,1350,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1350,870,390,870,1350,870,1380,870,390,870,1380,870,420,870,390,870,390,870,390,870,420,870,1380,870,1350,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,420,870,1380,870,1350,870,1380,870,1380,6990;
10;rfdebug=off;
20;15;RFDEBUG=OFF;
Stuntteam
Site Beheer
Re: WH2A (Branded as Lacrossetechnology and Tesa Weather Pro)
#2 Post by Stuntteam » 20 Jan 2017, 00:26
We are looking into it..
wormie_dk
#3 Post by wormie_dk » 27 Jan 2017, 14:29
42% 24,6 deg c (device 1)
20;26;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,420,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1350,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1350,870,1380,6990;
20;27;DEBUG;Pulses=46;Pulses(uSec)=1170,840,390,840,360,840,390,840,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1350,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;28;DEBUG;Pulses=100;Pulses(uSec)=1380,840,1320,840,360,840,1320,810,1380,870,390,870,420,870,1350,870,390,870,1350,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1350,870,390,870,1350,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
32% 23,5c (device 2)
20;34;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;35;DEBUG;Pulses=48;Pulses(uSec)=510,810,1290,840,1290,840,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1350,870,1380,870,1380,6990;
20;36;DEBUG;Pulses=98;Pulses(uSec)=1380,810,390,840,1290,810,1320,840,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
30%, 16,3c (device 1)
20;49;RFDEBUG=ON;
20;4A;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;4B;DEBUG;Pulses=46;Pulses(uSec)=450,810,360,840,1290,810,360,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;4C;DEBUG;Pulses=100;Pulses(uSec)=240,840,1290,810,1320,840,360,810,1320,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
10;rfdebug=off;
20;4D;RFDEBUG=OFF;
Stuntteam
Site Beheer
#4 Post by Stuntteam » 27 Jan 2017, 14:39
This should have been fixed...
visuel
#5 Post by visuel » 19 Apr 2017, 20:09
Did you manage to get the wh2a supported ?
I have such a sensor that I am trying to use in domoticz, but it just does not seem to get recognized.
8-)
wormie_dk
#6 Post by wormie_dk » 19 Apr 2017, 21:05
Mine work fine and are recognized. Did you remember to allow new devices in settings?
Exilebear
#7 Post by Exilebear » 05 May 2017, 18:23
Hmm I have bought 2 of the same but they are not being recognised by RFlink. According to firmware version 46 it should be supported. RFlink is receiving data of the devices, I can see this in debug mode.
Exilebear
#8 Post by Exilebear » 05 May 2017, 19:06
Update:
Some debug logging:
Logging... (RLink Firmware Version: 1.1 Revision: 46)
41% - 22,5
20;11;DEBUG;Pulses=108;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,420,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,420,870,390,6990;
42% - 22,6
20;14;DEBUG;Pulses=108;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,900,390,870,390,870,1380,870,390,870,390,870,390,900,390,870,1380,870,390,870,390,870,390,870,390,6990;
42% - 22,8
20;1B;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,420,870,1380,870,1380,870,1380,870,390,870,420,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,420,870,390,870,1380,870,420,870,390,6990;
41% - 22,8
20;1E;DEBUG;Pulses=110;Pulses(uSec)=420,870,390,900,390,870,390,870,390,870,390,870,390,870,1380,870,390,900,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,420,870,1380,870,1380,870,390,870,390,870,390,6990;
41% - 22,8
20;21;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,420,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,900,1380,870,1380,870,1380,870,390,870,390,900,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,900,390,870,1380,870,1380,870,390,870,1380,870,420,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,6990;
41% - 22,9
2017-05-05 19:12:15 - 20;48;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% - 22,9
(uSec)=420,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,420,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;4C;DEBUG;Pulses=46;Pulses(uSec)=630,840,360,840,1290,840,360,810,1350,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,420,870,1380,870,390,870,1380,870,1380,6990;
20;4D;DEBUG;Pulses=92;Pulses(uSec)=1380,840,1290,840,1290,810,390,840,360,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% - 22,9
2017-05-05 19:13:51 - 20;50;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,6990;
41% - 22,9
2017-05-05 19:14:39 - 20;53;DEBUG;Pulses=110;Pulses(uSec)=480,870,390,870,390,870,420,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,6990;
visuel
#9 Post by visuel » 22 May 2017, 08:23
Looks like I got a different sensor than that of wormie_dk: Pulses=110, just like the sensor of exilebear
:roll:
I found this on the interweb:
Would like to decode the debug pulses but have to start reading the docs.
Where to start best?
Update of my debug logging:
41% 20.3
2017-04-20 17:28:50 -
20;23;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
20;24;
DEBUG;Pulses=46;Pulses(uSec)=1380,840,360,840,1290,840,390,840,1380,870,1380,870,390,870,390,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
20;25;
DEBUG;Pulses=92;Pulses(uSec)=1380,810,1290,840,360,810,1320,840,360,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
42% 20.7
2017-04-20 17:29:38 -
20;26;
DEBUG;Pulses=110;Pulses(uSec)=420,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,6990;
42% 20.9
2017-04-20 17:30:26 -
20;27;
DEBUG;Pulses=110;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:31:14 -
20;28;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;29;
DEBUG;Pulses=46;Pulses(uSec)=1380,840,360,840,1290,840,360,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;2A;
DEBUG;Pulses=92;Pulses(uSec)=1380,810,1290,840,360,840,1290,840,360,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,900,1380,870,1380,870,390,870,1380,870,390,900,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:32:02 -
20;2B;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,900,1380,870,390,870,1380,870,1380,870,390,900,1380,870,390,870,1380,870,390,870,1380,900,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,900,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:32:50 -
20;2C;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,900,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:33:38 -
20;2D;
20;2E;
DEBUG;Pulses=46;Pulses(uSec)=1380,840,360,840,1320,810,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;2F;
(uSec)=1380,840,1290,840,390,810,1320,840,360,840,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
visuel
#10 Post by visuel » 22 May 2017, 10:50
So if we take a debug line, for example:
We get the following bits:
[size=85]
1	420,870,	1	Preamble
2	390,870,	1
3	390,870,	1
4	390,870,	1
5	390,870,	1
6	390,870,	1
7	390,870,	1
8	1380,870,	0	Sequence Delmiter
9	390,870,	1
10	1380,870,	0
11	1380,870,	0
12	390,870,	1	Device ID
13	1380,870,	0
14	390,870,	1
15	1380,870,	0
16	390,870,	1
17	1380,870,	0
18	1380,870,	0
19	1380,870,	0
20	1380,870,	0	Temperature reading =207
21	1380,870,	0
22	1380,870,	0
23	1380,870,	0
24	390,870,	1
25	390,870,	1
26	1380,870,	0
27	1380,870,	0
28	390,870,	1
29	390,870,	1
30	390,870,	1
31	390,870,	1
32	1380,870,	0	Relative Humidity reading =42
33	1380,870,	0
34	390,870,	1
35	1380,870,	0
36	390,870,	1
37	1380,870,	0
38	390,870,	1
39	1380,870,	0
40	1380,870,	0	Checksum + trailer
41	390,870,	1
42	1380,870,	0
43	1380,870,	0
44	1380,870,	0
45	1380,870,	0
46	1380,870,	0
47	1380,870,	0
48	1380,870,	0
49	1380,870,	0
50	1380,870,	0
51	1380,870,	0
52	1380,870,	0
53	1380,870,	0
54	390,870,	1
55	390,6990	1  STOP / START[/size]
Could not find a plugin for 110 pulses in the plugin source code.
Is there a plugin for above, or do I have to write my own?
visuel
#11 Post by visuel » 25 May 2017, 10:29
