SUPPORTED HARDWARE LIST - Please add your Hardware!
Following a recent discussion in the forum about supporting a specific sonoff hardware, i notice that the wiki currently lacks a "Supported Hardware" section, where new users can find a list of devices, breakout-boards or chips where ESP Easy can run on. This list would ideally contain the info how to flash ESP Easy on this devices and if needed useful stuff like rules specific for this device (e.g. switch relay on sonoff device with button)
Do get this started it would be nice if we could collect a list of currently tested devices... i started a stub on the wiki:
https://www.letscontrolit.com/wiki/inde ... d_Hardware
but this is only a stub, and i know not everyone does have a user on the wiki... so feel free to post your currently running hardware in this thread, best would be if you could post a photo of the hardware and every info which a beginner could need, especially info if something is not currently supported...
Would be really great if we would compile a usefull list for beginners!!
Re: SUPPORTED HARDWARE LIST - Please add your Hardware!
I support your cause and will try to contribute. Can I suggest that we make a table similiar to the input/output devices and include useful information in the table. I would like us to brainstorm which info that could be.
To start the process i would suggest:
1. ESP chip version of the device (like ESP8255, ESP-07,ESP12E, ESP12F)
2. Flash size
3. Onboard USB-TTL converter (if yes, what chipset)
4. GPIO's broken out/available to free use (ex. Sonoff: GPIO 1&3&15?) available to user
5. GPIO tied to onboard hardware (like relay, button, LED on a standard sonoff)
6. Power supply information ( like AMS 1117-3.3 on a NodeMCU)
7. Antenna (like onboard PCB antenna, onboard ceramic antenna, pigtail connector)
We can then make a wiki page for each device and add more specific information there. I think the main page of the wiki is getting a bit long...
2. Flash size
Very good initiative
In addition to previous suggestions, I'd like to see:
- Step-by-step details on how to flash (how to locate pins, voltage supported, etc.)
- Which plugin to use and how to setup that plugin
- General comments around that device
Please also add H801 LED Controller https://pl.aliexpress.com/store/product ... 23622.html as device. It only supports 3.3v on VCC and signalling pins (NOT 5V on those, then it burns).
![Erg Blij :D](./images/smilies/icon_e_biggrin.gif)
@krikk
I see you started something on the wiki. I edited it a little bit. I think we can keep the table on the main wiki and link the devices there.
I like the edit you did. I think also sensors should be listed in a table, the way it is presented now is very cluttered.
I also think we need to move the "Ventus W266" to a section called "modded hardware supported" or something. It is not a sensor in the raw sense. More modds will follow I think.
I just updated this: Wiki-pagegrovkillen wrote: ↑09 May 2017, 06:10 I think also sensors should be listed in a table, the way it is presented now is very cluttered.
I have checked it, but it still looks very similiar. Maybe the same approach as with the hardware devices could be useful.grovkillen wrote: ↑09 May 2017, 06:10I like the edit you did. I think also sensors should be listed in a table, the way it is presented now is very cluttered.
We create a table with some useful information and then write the specifics on the respective sensor page. To start the brainstorming some thoughts here:
1. Sensor name
2. measured physical sizes ( like Temperature and relative Humidity for a DHT11) and range ( -10°C -50 °C)
3. Power requirements ( like 13mA@3.3V)
4. connection method (like I2C, 1wire, 1 digital GPIO, 2 digital GPIO, A0 with Voltgage divider)
5. level shifter required (yes/no)
Added below:
1. Sensor name (should be chipset name. I.e. INA219 not "DC Current Sensor")
4b. output logic (digital/analog/both)
4c. i2c address (if multiple specify the default)
6. mounting method(s), if any (holes for pcb fasteners, etc.?)
I like the table, looks nice.
I've added the Sonoff 4ch to the table meanwhile.
When i learned how to make a page and a link i'll write a "HowTo flash the ch4" to the wiki....
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
I guess you could put the Eastron SDM Series of Energy Meters with MODBus connection (and the ones without MODBus have pulse out, so they would work with the pulse counter plugin as well) as soon as my plugin is finished. You _CAN_ use it as-is but I would like to add a lot more stuff.
http://eastrongroupco.hk02.057321.com/products/10.html
