Unable to flash dev7 to nodecmu v3 with arduino
ibot
#1 Post by ibot » 19 Mar 2017, 00:47
I am unable to flash v2.0.0-dev7 to nodemcu v3 via arduino ide on a linux system.
My configuration looks like this:
The upload looks successful
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
	setting board to nodemcu
	setting baudrate from 115200 to 115200
	setting port from /dev/ttyUSB0 to /dev/ttyUSB0
	setting address from 0x00000000 to 0x00000000
	espcomm_upload_file
	espcomm_upload_mem
opening port /dev/ttyUSB0 at 115200
	tcgetattr
	tcsetattr
	serial open
opening bootloader
resetting board
trying to connect
	espcomm_send_command: sending command header
	espcomm_send_command: sending command payload
trying to connect
	espcomm_send_command: receiving 2 bytes of data
Uploading 543488 bytes from /tmp/arduino_build_533117/ESPEasy.ino.bin to flash at 0x00000000
	erasing flash
	size: 084b00 address: 000000
	first_sector_index: 0
	total_sector_count: 133
	head_sector_count: 16
	adjusted_sector_count: 117
	erase_size: 075000
	setting timeout 15000
	setting timeout 100
	writing flash
................................................................................ [ 15% ]
................................................................................ [ 30% ]
................................................................................ [ 45% ]
................................................................................ [ 60% ]
................................................................................ [ 75% ]
................................................................................ [ 90% ]
...................................................                              [ 100% ]
starting app without reboot
closing bootloader
After upload in serial monitor
 1384, room 16
��!�’��d
~ld
�U
INIT : Booting version: (custom)
FS   : Mount successful
Resetting factory defaults...
RESET: Reboot count: 250
RESET: To many reset attempts
PID:0
Version:0
Exception (0):
epc1=0x40106f65 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff3910 end: 3fff3b80 offset: 01a0
>>>stack>>>
3fff3ab0:  0000001c 00000000 3fff2a9c 401004d8
3fff3ac0:  3fff2a9c 3fff2a9c 3fff5134 40202ea5
3fff3ad0:  00000000 00000001 000001a5 4010020c
3fff3ae0:  0000001c 00000000 3fff2a9c 00000000
3fff3af0:  0000001c 00000000 3fff2a9c 40235880
3fff3b00:  00000001 3fff293c 3fff2b60 3fff293c
3fff3b10:  3fffdad0 3fff2b58 402372f0 3fff2b58
3fff3b20:  3fffdad0 3fff2a9c 3fff1250 40207ded
3fff3b30:  3fffdad0 3fff2a9c 3fff1250 40220401
3fff3b40:  feefeffe feefeffe feefeffe 3fff5144
3fff3b50:  0000002f 00000023 feefeffe feefeffe
3fff3b60:  3fffdad0 00000000 3fff2b52 40237334
3fff3b70:  feefeffe feefeffe 3fff2b60 40100718
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(1,0)
 ets Jan  8 2013,rst cause:4, boot mode:(1,0)
After reboot in serial monitor
PID:0
Version:0
Exception (0):
ctx: cont
>>>stack>>>
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
�U
PID:0
Version:0
Exception (0):
ctx: cont
>>>stack>>>
<<<stack<<<
I tried different boards (Nodemcu v9, generic 8266).
Can somebody help?
Re: Unable to flash dev7 to nodecmu v3 with arduino
#2 Post by Shardan » 19 Mar 2017, 13:13
i can confirm that uploading with the arduino IDE does not work.
This is a misbehaviour of the Arduino loader!
My settings on a nodeMCU: nodeMCU 1.0 ESP12E, 1M SPIFFS.
Uploading works fine, booting results in an error:
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
ªU
RESET: Reboot count: 103
PID:0
Version:0
Exception (0):
ctx: cont
sp: 3fff4160 end: 3fff43d0 offset: 01a0
>>>stack>>>
3fff4300:  0000001c 00000000 3fff32e4 401004d8
3fff4310:  3fff32e4 3fff32e4 3fff550c 40202e39
3fff4320:  00000000 00000001 00000116 4010020c
3fff4330:  0000001c 00000000 3fff32e4 00000000
3fff4340:  0000001c 00000000 3fff32e4 402389c8
3fff4350:  00000001 3fff3184 3fff33b0 3fff3184
3fff4360:  3fffdad0 3fff33a0 4023a4bc 3fff33a0
3fff4370:  3fffdad0 3fff32e4 3fff1a50 40207de5
3fff4380:  3fffdad0 3fff32e4 3fff1a50 4022212d
3fff4390:  feefeffe feefeffe feefeffe 3fff551c
3fff43a0:  0000002f 00000023 feefeffe feefeffe
3fff43b0:  3fffdad0 00000000 3fff339a 4023a500
3fff43c0:  feefeffe feefeffe 3fff33b0 40100718
<<<stack<<<
The following workaround works:
I've used the "Ctrl - Alt + S" (export compiled binary) comand from Arduino IDE.
It builds a -bin-File in the same folder the ESPEasy.ino resides in.
I copied the .bin to my old flash tool from the R14x-versions and renamed it to ESPEasy_R200_4096.bin
Then i was able to flash it to my testing nodeMCU without issues:
INIT : Free RAM:24952
INIT : I2C
INIT : SPI not enabled
WIFI : No SSID!
WIFI : No SSID!
INIT : Normal boot
WD   : Uptime 0 ConnectFailures 0 FreeMem 19728
WD   : Uptime 1 ConnectFailures 0 FreeMem 19696
WD   : Uptime 1 ConnectFailures 0 FreeMem 19560
WD   : Uptime 2 ConnectFailures 0 FreeMem 19560
Users browsing this forum: Ahrefs [Bot] and 37 guests
