I have been trying in vein to get R45 installed and working on my gateway without luck. It flashes fine and appears to work fine, with Domoticz receiving both 2.4 and 433Mhz signals. However, when sending a 433MHZ signal, it shows as sucsessful but sends nothing.
I have tried using the RFLink Loader to send the commands directly from that and it shows an OK with a binary response but again, it doesn't actually send anything (Well, my devices do not respond, I could do with another RFLink to monitor what is actually being sent I guess).
If I revert back to R44, everything works just fine again. I read that shorting 12 and 13 to clear eeprom might work, that didn't for me anyway. I have tried multiple downloads in case of corrupt files etc. Same results every time.
Any Ideas on why or what to try next?
R45 - 433MHZ Send Doesn't Work Anymore
Re: R45 - 433MHZ Send Doesn't Work Anymore
check your email..
Many thanks, was not expecting a response so quick and I can confirm it works a charm! Problems all gone and 433 is sending perfectly!
Many thanks, really appreciate it!
Kris
Kris
Would you mind sharing the solution?
It was a specific issue back in 2017 with a very old release.
This is no longer relevant for the current release version.
Users browsing this forum: Ahrefs [Bot] and 0 guests
