WH2A (Branded as Lacrossetechnology and Tesa Weather Pro)
Would it be possible to add support for the WH2A transmitter. I purchased mine from: https://www.aliexpress.com/item/Transmi ... 0.0.Ihdr0l
But can also be seen here:
http://shop.lacrossetechnology.com.au/t ... itter.html
Log is below for temperature around 26,7 and humidity around 41 %:
10;rfdebug=on;
20;0C;RFDEBUG=ON;
20;0D;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,420,870,1380,870,420,870,390,870,1380,870,420,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;0E;DEBUG;Pulses=48;Pulses(uSec)=450,810,360,840,1320,810,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;0F;DEBUG;Pulses=100;Pulses(uSec)=60,840,1290,840,1290,840,1290,840,1350,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,390,870,420,870,390,870,390,870,390,870,1350,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1350,870,1380,6990;
20;10;DEBUG;Pulses=222;Pulses(uSec)=1410,1410,2070,660,600,2130,2070,660,600,2130,2100,660,600,2130,2070,660,2070,660,2070,660,2100,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,600,2130,600,2130,600,2130,600,2130,1350,1410,2070,660,600,2130,2070,660,630,2130,2070,660,600,2130,2070,660,2070,660,2070,660,2070,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,600,2130,630,2130,600,2130,630,2130,1350,1410,2070,660,600,2130,2070,660,630,2130,2070,660,600,2130,2070,660,2070,660,2070,660,2070,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,630,2130,600,2130,600,2130,600,2130,1350,1380,2070,660,630,2130,2070,660,600,2130,2070,660,600,2130,2100,660,2070,660,2070,660,2100,660,2070,660,2070,660,600,2130,2070,660,2070,660,600,2130,600,2130,630,2130,600,2130,600,2130,600,2130,1350,1380,2070,660,600,2130,2100,660,600,2130,2070,660,600,2130,2070,660,2070,660,2100,660,2070,660,2070,660,2070,660,600,2130,2070,660,2070,660,600,2130,630,2130,630,2130,600,2130,600,2130,600,2130,1230,6990;
20;11;Biltema;ID=0002;TEMP=00dd;HUM=32;
20;12;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,900,390,870,420,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;13;DEBUG;Pulses=48;Pulses(uSec)=360,840,360,840,360,810,390,810,360,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,420,870,1380,870,1380,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,1380,6990;
20;14;DEBUG;Pulses=98;Pulses(uSec)=1380,810,1320,810,1290,840,360,840,1350,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1350,870,390,870,1350,870,1380,870,390,870,1380,870,420,870,390,870,390,870,390,870,420,870,1380,870,1350,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,420,870,1380,870,1350,870,1380,870,1380,6990;
10;rfdebug=off;
20;15;RFDEBUG=OFF;
10;rfdebug=on;
20;0C;RFDEBUG=ON;
10;rfdebug=off;
20;15;RFDEBUG=OFF;
Re: WH2A (Branded as Lacrossetechnology and Tesa Weather Pro)
We are looking into it..
42% 24,6 deg c (device 1)
20;26;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,420,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1350,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1350,870,1380,6990;
20;27;DEBUG;Pulses=46;Pulses(uSec)=1170,840,390,840,360,840,390,840,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1350,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;28;DEBUG;Pulses=100;Pulses(uSec)=1380,840,1320,840,360,840,1320,810,1380,870,390,870,420,870,1350,870,390,870,1350,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1350,870,390,870,1350,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
32% 23,5c (device 2)
20;34;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;35;DEBUG;Pulses=48;Pulses(uSec)=510,810,1290,840,1290,840,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1350,870,1380,870,1380,6990;
20;36;DEBUG;Pulses=98;Pulses(uSec)=1380,810,390,840,1290,810,1320,840,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
30%, 16,3c (device 1)
20;49;RFDEBUG=ON;
20;4A;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;4B;DEBUG;Pulses=46;Pulses(uSec)=450,810,360,840,1290,810,360,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;4C;DEBUG;Pulses=100;Pulses(uSec)=240,840,1290,810,1320,840,360,810,1320,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
10;rfdebug=off;
20;4D;RFDEBUG=OFF;
20;49;RFDEBUG=ON;
10;rfdebug=off;
20;4D;RFDEBUG=OFF;
This should have been fixed...
Did you manage to get the wh2a supported ?
I have such a sensor that I am trying to use in domoticz, but it just does not seem to get recognized.
![Cool 8-)](./images/smilies/icon_cool.gif)
Mine work fine and are recognized. Did you remember to allow new devices in settings?
Hmm I have bought 2 of the same but they are not being recognised by RFlink. According to firmware version 46 it should be supported. RFlink is receiving data of the devices, I can see this in debug mode.
Update:
Some debug logging:
Logging... (RLink Firmware Version: 1.1 Revision: 46)
41% - 22,5
20;11;DEBUG;Pulses=108;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,420,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,420,870,390,6990;
42% - 22,6
20;14;DEBUG;Pulses=108;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,900,390,870,390,870,1380,870,390,870,390,870,390,900,390,870,1380,870,390,870,390,870,390,870,390,6990;
42% - 22,8
20;1B;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,420,870,1380,870,1380,870,1380,870,390,870,420,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,420,870,390,870,1380,870,420,870,390,6990;
41% - 22,8
20;1E;DEBUG;Pulses=110;Pulses(uSec)=420,870,390,900,390,870,390,870,390,870,390,870,390,870,1380,870,390,900,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,420,870,1380,870,1380,870,390,870,390,870,390,6990;
41% - 22,8
20;21;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,420,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,900,1380,870,1380,870,1380,870,390,870,390,900,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,900,390,870,1380,870,1380,870,390,870,1380,870,420,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,6990;
41% - 22,9
2017-05-05 19:12:15 - 20;48;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% - 22,9
(uSec)=420,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,420,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;4C;DEBUG;Pulses=46;Pulses(uSec)=630,840,360,840,1290,840,360,810,1350,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,420,870,1380,870,390,870,1380,870,1380,6990;
20;4D;DEBUG;Pulses=92;Pulses(uSec)=1380,840,1290,840,1290,810,390,840,360,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% - 22,9
2017-05-05 19:13:51 - 20;50;DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,6990;
41% - 22,9
2017-05-05 19:14:39 - 20;53;DEBUG;Pulses=110;Pulses(uSec)=480,870,390,870,390,870,420,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,6990;
Some debug logging:
41% - 22,5
42% - 22,6
42% - 22,8
41% - 22,8
41% - 22,8
41% - 22,9
41% - 22,9
41% - 22,9
41% - 22,9
Looks like I got a different sensor than that of wormie_dk: Pulses=110, just like the sensor of exilebear
I found this on the interweb:
![Image](https://lh3.googleusercontent.com/-43TNXJ2wFuo/WJaGM1-9uWI/AAAAAAAAA04/GjkYhXe0k1k1NMqN0kKgf2BeZtjCQBJmwCLcB/s1600/data.png)
Would like to decode the debug pulses but have to start reading the docs.
Where to start best?
Update of my debug logging:
41% 20.3
2017-04-20 17:28:50 -
20;23;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
20;24;
DEBUG;Pulses=46;Pulses(uSec)=1380,840,360,840,1290,840,390,840,1380,870,1380,870,390,870,390,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
20;25;
DEBUG;Pulses=92;Pulses(uSec)=1380,810,1290,840,360,810,1320,840,360,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
42% 20.7
2017-04-20 17:29:38 -
20;26;
DEBUG;Pulses=110;Pulses(uSec)=420,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,6990;
42% 20.9
2017-04-20 17:30:26 -
20;27;
DEBUG;Pulses=110;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:31:14 -
20;28;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;29;
DEBUG;Pulses=46;Pulses(uSec)=1380,840,360,840,1290,840,360,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;2A;
DEBUG;Pulses=92;Pulses(uSec)=1380,810,1290,840,360,840,1290,840,360,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,900,1380,870,1380,870,390,870,1380,870,390,900,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:32:02 -
20;2B;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,900,1380,870,390,870,1380,870,1380,870,390,900,1380,870,390,870,1380,870,390,870,1380,900,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,900,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:32:50 -
20;2C;
DEBUG;Pulses=110;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,900,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
41% 20.9
2017-04-20 17:33:38 -
20;2D;
20;2E;
DEBUG;Pulses=46;Pulses(uSec)=1380,840,360,840,1320,810,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
20;2F;
(uSec)=1380,840,1290,840,390,810,1320,840,360,840,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
![Rollende Ogen :roll:](./images/smilies/icon_rolleyes.gif)
41% 20.3
20;23;
20;24;
20;25;
42% 20.7
20;26;
42% 20.9
20;27;
41% 20.9
20;28;
20;29;
20;2A;
41% 20.9
20;2B;
41% 20.9
20;2C;
41% 20.9
20;2D;
20;2E;
20;2F;
So if we take a debug line, for example:
We get the following bits:
Could not find a plugin for 110 pulses in the plugin source code.
Is there a plugin for above, or do I have to write my own?
[size=85]
1 420,870, 1 Preamble
2 390,870, 1
3 390,870, 1
4 390,870, 1
5 390,870, 1
6 390,870, 1
7 390,870, 1
8 1380,870, 0 Sequence Delmiter
9 390,870, 1
10 1380,870, 0
11 1380,870, 0
12 390,870, 1 Device ID
13 1380,870, 0
14 390,870, 1
15 1380,870, 0
16 390,870, 1
17 1380,870, 0
18 1380,870, 0
19 1380,870, 0
20 1380,870, 0 Temperature reading =207
21 1380,870, 0
22 1380,870, 0
23 1380,870, 0
24 390,870, 1
25 390,870, 1
26 1380,870, 0
27 1380,870, 0
28 390,870, 1
29 390,870, 1
30 390,870, 1
31 390,870, 1
32 1380,870, 0 Relative Humidity reading =42
33 1380,870, 0
34 390,870, 1
35 1380,870, 0
36 390,870, 1
37 1380,870, 0
38 390,870, 1
39 1380,870, 0
40 1380,870, 0 Checksum + trailer
41 390,870, 1
42 1380,870, 0
43 1380,870, 0
44 1380,870, 0
45 1380,870, 0
46 1380,870, 0
47 1380,870, 0
48 1380,870, 0
49 1380,870, 0
50 1380,870, 0
51 1380,870, 0
52 1380,870, 0
53 1380,870, 0
54 390,870, 1
55 390,6990 1 STOP / START[/size]
