PWM, Value 1 to 5 flashes
BerndJ
#1 Post by BerndJ » 09 Oct 2015, 22:15
had a problem when i would like to use the PWM function by the above mentionend values. greater value 5 everything works fine.
is it a esp problem?
Idea: nice and a dream could be a dimming function, like:
http://<ESP IP address>/control?cmd=Dim,<pin>,<Startlevel>,<Endlevel>,<time>
best wishes
Bernd
asm7100
Re: PWM, Value 1 to 5 flashes
#2 Post by asm7100 » 10 Oct 2015, 10:53
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
BerndJ
#3 Post by BerndJ » 10 Oct 2015, 11:09
done, what did i not see?
http://<ESP IP address>/control?cmd=PWM,13,1
and also up to
http://<ESP IP address>/control?cmd=PWM,13,5
and the output Pin GPIO13 flashes, no constant level.
http://<ESP IP address>/control?cmd=PWM,13,0
and up of
http://<ESP IP address>/control?cmd=PWM,13,6
is OK.
Could anybody test it and confirm?
Bernd
asm7100
#4 Post by asm7100 » 10 Oct 2015, 12:03
BerndJ
#5 Post by BerndJ » 10 Oct 2015, 14:04
Sorry,
i must bee blind, do´nt see any solution regarding these problem on these site.
Take a resistor and a led, put it to one port and send the command with level 3 to this port.
Did u had a constant Light??
I had testet some boards, all of them have these problem, the led flashes.
If i send level 6 all is fine.
Where is the solution (pls don´t repeat yr answer for 3rd time) ?????
