Have someone for sharing eagle files for Rflink for all RF modules?
Something like this https://www.nodo-shop.nl/nl/rflink-gate ... enten.html but also with:
NRF24L01 - MiLight / Applamp / Limitless Led support
CC2500 - 2.4 Ghz: Philips Living Colors / Ikea Ansluta support
Regards,
MiKa
RF link new PCB
Re: RF link new PCB
I think that this files are "not for share"
I am also interested if someone can share them...
Re: RF link new PCB
There is now a PCB design available for an RFLink shield in the EasyDomoticz forum:
https://easydomoticz.com/forum/viewtopic.php?t=4068
I built the second (larger) version with the two 433MHz RX/TX and antennas and the nrf24l01. As my arduino mega has already an esp8266 directly on the mega board, I didn't use the ESP-01.
The 433MHz RX/TX and the NRF24 are working just fine so far.
Re: RF link new PCB
I also built the shield with the ESP-01 and it works fine with one caveat : the pcb versions available for download forgot to connect the 3V3, 5V and GND pins of the level shifters for the ESP. I manually soldered some wires torn the voltage regulators to make it work just fine. I also connected the 5V of the ESP's regulator directly to the other regulator's 5V input, so I draw 5V for the esp from the arduino rather than from a second micro USB power supply...
Now the shield works fine, in particular together with my new ESPEasy RFLink to MQTT bridge plugin (PR submitted to the plugin playground)
Users browsing this forum: Ahrefs [Bot] and 3 guests
