R45 Changelog:
- New Device: Silvercrest switch set IAN276299
- New Device: Silvercrest switch set IAN113854
- New Device: Silvercrest switch set IAN91210
- New Device: Quigg switch set GT-9000 (Tevion/Globaltronics/ALDI)
- New Device: Unitec switch set 4811 model 50028 (Intertek)
- New Device: Cotech switch set 36-6361
- New Device: Sartano switch set, Model 50028, HN 10047
- New Device: Electro Depot switch set, article code 940557
- New Device: BL999 weather sensor
- New Device: Digi-Tech 4-LD14554 Outdoor temperature sensor (Thanks: PJA)
- New Device: PLC-T4022G X10 RF to Powerline
- New Device: X10 UR76 E Remote Control
- New Device: Konig Alarm system sensors
- New Device: Alecto 1200 alternative protocol version
- New Device: Oregon EW99
- New Device: Smartwares RM174RF Smoke detector
- New Device: FirstLine FWS802 Pool Thermometer (Thanks: BC)
- New Device: Liwin Shutters / Blinds controller
- Fixed: MiniGPIO command structure
- Fixed: Conrad RSL pair command added
- Fixed: Warema EWFS (Thanks: SH)
- Fixed: Removed Ningbo debug message
- Fixed: Mebus protocol detection for Auriol Z29536 IAN55982
- Fixed: Removed debug messages on Atlantic protocol
- Fixed: Milight color and brightness changing on groups
- Fixed: DKW2012 Humidity conversion
- Fixed: DKW2012 Wind speed conversion (Thanks: HJ)
- Fixed: Xiron ID sometimes had an incorrect bit
- Fixed: Blyss/Avidsen transmit
- Fixed: Aster protocol split on/off and dim/bright into separate devices
- Fixed: Improved detection of WH5029
- Fixed: Improved HE800 protocol detection
- Fixed: Improved detection of Cleverwatts, Kerui and compatible devices
- Fixed: Proper handling of incoming serial commands for KAKU and related devices
- Fixed: Improved Chacon EMW200 detection
- Added: RTS protocol option to swap ON/OFF command
- Added: RTS long TX option to extend the RTS transmit time
- Added: "Settings reset" feature
- Added: Extended Gaposa protocol
- Added: Lacrosse V3 protocol support for negative temperature values
Available on www.nemcon.nl/blog2
Enjoy!
New RFLink firmware (R45) now available!
Re: New RFLink firmware (R45) now available!
Still no integration with MySensors ?
That was added in R44.
It does require some small changes to keep the mysensors slave devices working though.
ok then it would be better to wait to disconnect the MySensors gateway for now.
How to connect the hardware on the arduino?
