RFLink release 38 is available for download
Information and news about RFLink development and releases
Stuntteam
Site Beheer
#1 Post by Stuntteam » 10 Mar 2016, 19:00
R38:
Note: Elmes changed into Keyloq you might have to re-learn the device..
- New Device: Initial NodoNRF sensor receive support (2.4ghz) (Thanks: Martinus)
- New Device: Nodo 3.8 slave support
- New Device: Catching of anti-tampering for Atlantic sensors
- New Device: Oregon, extra checks for out of range values
- New Device: Tunex MF-0211 temperature sensor
- New Device: Alecto V3 Rain - Alternative version of WS1200
- New Device: Byron SX21
- New Device: MC145026 based sensors
- New Device: FunkBus remote control support (Insta/Berker/Gira/Jung) (receive only) (Thanks: D.)
- New Device: Kingpin motor controls
- New Device: Livolo
- New Device: Koch remote controls
- New Device: Additional X10 protocol devices
- New Device: Forest "Touch Sense Motors" Curtain control (Thanks: JPe)
- New Device: Faher motor controller DC305, DC307
- New Device: Biltema 84056 temperature and humidity sensor
- New Device: Logipark
- New Device: Friedland EVO doorbell Decor ED1/ED3 (receive only)
- New Device: Friedland DC4 PIR
- New Device: Lobeco door sensors
- New Device: Hadex T093, WH5029
- New Device: FineOffset Temperature & Humidity sensors
- New Device: XT200 temperature sensor
- New Device: Conrad RSL blind controller 640579
- New Device: Smartwares SH5-TDR-A / SHS 5300 Heating Controller / Radiator Valve (Initial support)
- New Device: BFT port opener remotes (Thanks: CS.)
- New Device: Etekcity ZAP
- Added: Oregon, extra checks for out of range values
- Fixed: Oregon Rain sensors (PCR800 and others) (Thanks: D.)
- Fixed: Oregon humidity
- Fixed: Esic WT450H detection
- Fixed: Alecto V1 wind speed values
- Fixed: Alecto V3 Rain values and added battery level support (Thanks: D.)
- Fixed: EverFlourish EMW203T detection
- Fixed: Xiron/Aok humidity
- Fixed: Added more range checks on Aster protocol
- Fixed: Optimized Conrad RSl transmit function
- Fixed: Additional checks on Keeloq protocol
- Fixed: Additional checks on Chuango protocol
- Fixed: Improved EV1527 / Chuango recognition (some issues left)
- Fixed: Added support for the ProMax master buttons
- Fixed: Improved ProMax signal detection
- Fixed: Some changes to X10 command parsing (Thanks: JPe)
- Fixed: RTS increased broadcast time
- Fixed: Ikea Koppla transmit bug
- Fixed: Ikea Koppla dimming issue
- Fixed: Oregon wind speed
- Changed: Created a seperate Novatys plugin
- Changed: Smoke detectors now respond as a switch as well
- Changed: Corrected Elmes label into Keyloq label
- Changed: Splitted the WS1100/WS1200 plugin to improve compatibility
- Changed: Improved WS1200 signal handling
- Changed: Improved incoming command parsing
- Changed: Big speed-up for plugin 1 converted packets
- Changed: Regrouped plugins so new ones can be added more easily
BertB
Re: RFLink release 38 is available for download
#2 Post by BertB » 06 Apr 2016, 10:30
I am using R38, but still have incorrect Alecto V1 wind values.
Since this problem is there as long as RFLink exists and I reported on that many times, I start believing the problem can not be solved.
Good old Nodo-Domotica does not suffer from this problem.
Stuntteam
Site Beheer
#3 Post by Stuntteam » 07 Apr 2016, 16:30
That should work with R40.
BertB
#4 Post by BertB » 08 Apr 2016, 15:59
R40 works just fine now. Thanks.
