Neopixel Basic P038 Multiple instances
HomeJCL
#1 Post by HomeJCL » 10 Jan 2022, 18:00
Subject sums it all.
Is it possible to have multiple NeoPixel Basics plugins running ?
I have access to both of the strips but only with 1 instance in Devices.
At time, it is one or the other.
Not that it is crucial.
HomeJCL
Re: Neopixel Basic P038 Multiple instances
#3 Post by HomeJCL » 10 Jan 2022, 19:22
Need to up my configuration skills in the meantime :lol:
#4 Post by Ath » 11 Jan 2022, 20:18
I've created a pull request #3909 to add multi-instance as a feature for the NeoPixel (Basic) plugin (P038).
Most likely the Github action builds won't complete, what .bin file are you using?, then I'll upload that build here.
HomeJCL
#5 Post by HomeJCL » 11 Jan 2022, 21:48
Tried all of them, standard would be ESP_Easy_mega_20211224_normal_ESP32_4M316k
#6 Post by Ath » 11 Jan 2022, 23:22
A local build for PR #3909, that should allow multiple NeoPixel (Basic) tasks to be configured and controlled separately:
ESP_Easy_mega_20220111_normal_ESP32_4M316k.zip
(1.84 MiB) Downloaded 177 times
HomeJCL
#7 Post by HomeJCL » 12 Jan 2022, 08:24
It works … when you address the right one :roll:
Many thanks.
Can make time for the application now. Hopefully my part goes as slick as your support :lol:
For the record https://espeasy.readthedocs.io/en/late ... f-a-plugin
#8 Post by Ath » 12 Jan 2022, 08:57
Thanks for testing, and the confirmation :)
HomeJCL
#9 Post by HomeJCL » 12 Jan 2022, 19:40
Does this means standard implementation in future releases ?
Thanks again.
The Mrs asked for other stuff.
Technology when it works : goes from pfff superfluous to can you also do this :D
#10 Post by Ath » 12 Jan 2022, 19:58
Yes, this is one of the plugins in the NORMAL builds, so it will be in nearly all available builds once it is merged and released (well, 'max', 'normal' and 'test' that is, the minimal and hardware specific builds don't have this plugin included).
HomeJCL
#11 Post by HomeJCL » 02 Mar 2023, 18:45
Just tried to update an old setup.
Seems P038 multiple instances is no longer "working" in release after 20220427.
I have tried, I think all of them, after this release date, but no success.
Can you confirm ?
#12 Post by Ath » 02 Mar 2023, 19:00
There is no reason for that, has been tested recently here, so should work fine.
HomeJCL
#13 Post by HomeJCL » 13 Mar 2023, 19:15
Hi Erased and Erased more, pushed an “empty” file … and succes
Sorry for late reply, ESP is a testbed for a lot of things and for some reason I tested another platform, which left crumbles to make me think ESPEasy was the solution.
Mae culpa …
I believe again and even more :D ESPEasy is alive again
