i start working with ESPeasy (actual Version) and d1 mini (ESP12F). For a Project via MQTT i need http://192.168.X.X/?cmd=deepSleep,60 or http://192.168.X.X/control?cmd=deepSleep,60. In the reference it's written like these commands. I try both... on esp i got a Message "command not found". (Bridge between RST and GPIO16 is done)
With rules deepsleep is working and calling GPIO works perfect too.
http://192.168.X.X/control?cmd=GPIO,12,1
Any ideas?
cheers, Andy
Calling Deepsleep with HTTP not working
Re: Calling Deepsleep with HTTP not working
Deepsleep is an internal command, so not accepted from an external source you are doing right now.
Alternative: implement an event in rules that starts deepsleep:
then call that event like this: http://192.168.x.x/control?cmd=event,StartDeepSleep=60
NB: Event names are not case-sensitive
on StartDeepSleep do
deepsleep,%eventvalue1% // First argument provided is the sleep-time in seconds, when 0 device will only wake up by pulling RST to GND!
Thank's very much for the good Solution for that
Great to hear you got it working, thank you for the feedback
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 38 guests
